Old 08-10-2015, 12:58 PM   #37
timmiller
Tim Miller
Drives: White 2007 Yaris 4-door
Thanks Guys- Was going crazy because the mechanical assembly fell off and was hiding behind the housing...until I saw these photos, I would have given up...but keep digging around until I found it. Happy Yaris Owner.
timmiller is offline   Reply With Quote
Old 12-07-2015, 11:56 AM   #38
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
This very issue happened to me last night on my 2010 Yaris 4 door hatchback. I'm kinda heavy handed at times. In the aforementioned photos , do these dash panels (where the fan speed and recirculation knob is) "pop" off easily? Pull straight out or push panels in slightly to get them too release??? TIA
frog13 is offline   Reply With Quote
Old 12-07-2015, 04:30 PM   #39
Yes. Just pull straight back starting with the bottom corners.
Old 12-08-2015, 12:11 AM   #40
frog13
Tw200--excellent!
Thanks Scott , this Forum is a vital necessity. Thanks to all.
Old 12-08-2015, 06:01 PM   #41
frog13
Tw200--excellent!
I haven't started disassembly yet. Any clue as to why the mechanism / cable maufunctions ?. Is there a screw that needs a bit of lock tight applied?. TIA
Old 12-08-2015, 06:03 PM   #42
frog13
Tw200--excellent!
What the heck , the print on my last post is micro???.
Old 12-08-2015, 07:25 PM   #43
No. The cable carrier assembly just snaps into place. The issue is that if the cable or what it drives binds and you force the cable, you pop the carrier out.
Old 12-08-2015, 11:45 PM   #44
frog13
Tw200--excellent!
Understood , thank you. When I eventually get too this , I'll look for binding points / lube points.
Old 07-04-2016, 03:40 PM   #45
rendrag
Drives: 2009 Yaris Sedan
Just Fixed my 2009 Yaris
Had the same problem and just fixed it thanks for the posts and pictures
rendrag is offline   Reply With Quote
Old 10-22-2016, 11:07 AM   #46
thebassline
Drives: 2007 Yaris Sedan
Thanks everyone for the help and pictures. My issue ended up being the actual flap being stuck and not allowing it to move. Taking out the glove box, following the cable to figure out where the mechanism was and moving it manually cleared up whatever gunk had been accumulating and allowed the dial to move normally. Attached some pictures of that in case anyone was interested.IMG_0380.JPGIMG_0381.JPG
thebassline is offline   Reply With Quote
Old 08-03-2017, 08:36 AM   #47
rehan86
Drives: Toyota Yaris HB (Vitz)
Thanks a lot!! You have saved me my money and time at the garage.
Today I did it and only took 5 - 10 mins.
rehan86 is offline   Reply With Quote
Old 06-26-2020, 05:40 AM   #48
yarishatchback
Drives: 2007 yaris 1.5
I’ve had this problem now for a while ...I HOPE THIS HELPS!!!
Inside my glove compartment where the flap is for the vent , it had a wiring harness cable that fell in front of the flap ... when the glove box is closed it was pushing against the wires that fell
In front of the vent flap...
Try opening the glove box and then try to flip the vent ... if it flips easy , pop the glove box out and check to see if there is anything impending the vent .
That was my fix for a tight vent cable...
yarishatchback is offline   Reply With Quote
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
