![]() Drives: 2009 Yaris T3 Join Date: Aug 2020
When I got the car, the speedometer (digital) wasn't working (still isn't) and the ABS and handbrake lights are on on the dash. When I scan the car I get codes for the two front wheel sensors and the rear right hand side one. Could the sensors themselves be faulty? I understand that the rear sensor is integrated into the hub so I have to replace the whole hub. Is there anyway to test the sensor using a multimeter perhaps? I'd hate to repace the sensors only to find that the bearings are the fault so if theres any way to narrow down the fault point I would highly appreciate it. Thanks for all that have contributed thus far you guys have been a great help.
| Tags |
| abs, outer cv, speed sensor |
| Dealer: $1,800 to replace rear ABS speed sensors on 2010 Yaris sedan | stormhighway | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-22-2019 09:12 PM |
| Can't find front hub bearing assembly with ABS anywhere! | PrettyWreckless | DIY / Maintenance / Service | 5 | 04-09-2018 04:15 PM |
| FRONT ABS | htschek | DIY / Maintenance / Service | 1 | 08-05-2013 10:14 PM |
| Front Lip 2009-10?? / will this work? / JDM | 3cyltrbo | Cosmetic Modifications (Exterior/Interior) | 1 | 04-08-2013 03:35 PM |
| FS: Rear ABS sensors off JDM Vitz RS $60/ea | enviri | Items for Sale by private party | 2 | 12-02-2012 11:08 PM |
