Old 03-22-2021, 03:35 PM   #20
chemicalstorm
Drives: Car
@shepd: Thanks a lot!!!
I've had the exact same problem. Ended up mustering enough courage to buy a welder, practice a bit and then weld the now-freed captive nut to be able to unbolt the lower control arm. Worked flawlessly.
I tried to close the hole and weld it back, but it turned out to be a bit difficult to pry the metal back into position, so I chose to leave it as-is.
chemicalstorm is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
