Old 08-07-2021, 05:59 PM   #1
mik23
Drives: yaris 2005
1NRFE Spark Plug SC16HR11 Recommendation Pls
Hi
The car has only done 50k 1NRFE Engine
I have taken out spark plug and cleaned them with cleaner due to lack of power sometime.
Can anyone help if they need replacement
No codes
No DTC
No stalling
No shaking
Car runs fine however i noticed on torque software misfire count so i am bit confused
any recommendation would be highly appreciated.
mik23 is offline   Reply With Quote
Old 08-08-2021, 02:02 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
ignition coils work in tandem with your plugs so check them on the particular cylinder with misfire.
rayfloyd170 is offline   Reply With Quote
Old 08-08-2021, 11:49 AM   #3
mik36
Drives: VERSO S
How can I test the coils than ?
mik36 is offline   Reply With Quote
Replacing spark plug wire with bell wire bronsin Off-topic / Other Cars / Everything else Discussions 1 11-11-2020 01:17 PM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
Spark plug replacement vinny121 DIY / Maintenance / Service 3 08-29-2013 12:25 PM
Spark plug Question please :) lamadoo DIY / Maintenance / Service 8 04-08-2013 11:55 AM
How hard I should try to remove spark plug mf4361 DIY / Maintenance / Service 24 03-30-2013 02:07 PM
