![]() Drives: 08 4-dr hatchback Join Date: Jul 2016
HELP Aux input install in canadian 2008 hatchback
Hi internet, first post here!
I recently acquired a 2008, 4-dr Yaris hatchback and so far I'm loving it... Until I noticed there's no way to play my music over the car speakers. The CD player doesn't read my burned CDs and I'm not fucking around with the low quality sound of FM transmitters. So I figured: AUX CORD! I've read other forums and pulled up the trim and I have figured out that the car was wired for an aux adapter that would have gone behind the gear shifter, but mine didn't come with the 3.5mm port. (see pic 1 at bottom of post). Yet when I trace harness back the HU, it's not actually plugged into anything anyways. Someone else said that's because the Canadian Yaris' received outdated HU's installed by the dealership, not the factory(?) The HU part number is 08600-00980, made by Fujitsu. (pic 2) When I pulled it out, I noticed there were 3 connectors running towards the HU. 2 plugged in, the other not. There was also a 3rd unused terminal on the far left of the rear of the HU (pic 3) however it didn't fit the remaining connector. (said connector in pic 4) After some poking around on the google, I found a pinout for the terminals of this specific HU (pic 5). Now it would appear that the cn702 5 + 7 pin connector on the left has the capability to receive an audio input. Is there any idiot-proof 3.5mm to cn702 12p adapter out there that will feed a stereo signal from my phone into this terminal and play thru the car? Or would soldering the Rch, Lch and shield wires from an old set of headphones (male 3.5mm on the other end obvi) to pins 1, 2 and 3 work just as well? If that won't work, I could guess why...I notice a R+ and L+ as well as R- and L- in the pinout sheet.....what's the difference, are these ch(-) necessary? The stereo is currently out of the car, sitting in 6 different pieces on my workbench atm ready to be fiddle-fucked with and have this project completed. Plz helps, ~Jack pic 1 http://imgur.com/RlHESCY pic 2 http://imgur.com/MnGLvB0 pic 3 http://imgur.com/hfgR3cz pic 4 http://imgur.com/prABImv pic 5 http://imgur.com/JvQCpln |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
http://www.yarisworld.com/forums/showthread.php?t=56732
Another cheap and easy option. I prefer USB. |
#4 | |
![]() Drives: 2008 Yaris 3dr Join Date: Aug 2020
| Tags |
| 2008, aux cord, canadian, hatchback, install |
| Aux Input Wire | nobleboy | In Car Entertainment + Electronics (audio / video / alarm) | 25 | 06-03-2015 05:25 AM |
| Loose aux input? | stellar | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 08-14-2011 08:36 PM |
| Aux Input Trouble | boeduur | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-07-2011 11:44 AM |
| Aux Input options | Kru | DIY / Maintenance / Service | 3 | 10-30-2009 02:05 PM |
| Help : AUX input in the factory HU | Hossam | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 08-25-2009 11:46 PM |
