Old 08-15-2022, 05:58 PM   #4
RMcG
Drives: Yaris manufactured after 2007
Originally Posted by sh0rtlife View Post
obd wont tell you anything about the headlight warnings or door sensors
funny tho i want to find this buzzer just to "hush" it some..im not sold that they are the same unit due to the change in sound for headlight key and seatbelt/seat weight
Thanks sh0rtlife,
I checked with O'Reilly's Auto Parts who does free OBD checks, but their OBD checks only work if the check engine light is on.
Regarding the buzzers being the same for key and headlight, I didn't really think about whether the sounds are the same or not until the headlight reminder failed. So I can't compare them, although based on my memory, which is fallible, I seem to think they sound the same or similar.
I think I am going to call a dealer and repair shop and just ask what they think it would cost to diagnose and fix the problem.
Some workarounds: 1) Buy a Car Battery Starter, like this one or another one.
Or 2) a simple EASY, Headlight reminder buzzer install DIY would probably work. You wire to the fuses in the fusebox. In thinking about this, if you trace the flow of current, and connect the buzzer wires to the correct "sides" (+ or -) of the fuses, you should not defeat the purpose of the fuses. In other words, you can make the current that flows through the buzzer also flow through the fuses. Since the buzzer probably does not draw much current, this should also not effect the car much. This buzzer for example, draws only 16 mA (milliamps) at 12 volts
Both of these workarounds probably cost less than a shop repair of the problem. Edit: I just called one reputable non Dealer repair shop and they said only a Dealer could diagnose & repair this problem. And I called two local Toyota Dealers and the diagnostic part of the job alone would run about $200.
Thanks,
R.
RMcG is offline   Reply With Quote
Tags
buzzer, headlight, reminder
Instrument cluster swapout help JudgeM DIY / Maintenance / Service 39 08-30-2025 09:19 PM
Headlight Reminder and Gauge Illumination not working Nogoldformarfa DIY / Maintenance / Service 0 09-18-2018 12:09 AM
2007 yaris instrument cluster dead and engine won't start dchippowski DIY / Maintenance / Service 2 05-17-2015 11:00 AM
Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback AndyW Willing to Buy by private party 6 12-07-2014 08:53 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
