Old 08-16-2022, 07:05 PM   #5
RMcG
Drives: Yaris manufactured after 2007
Originally Posted by RMcG View Post
Thanks sh0rtlife,
Some workarounds: 1) Buy a Car Battery Starter, like this one or another one.
Or 2) a simple EASY, Headlight reminder buzzer install DIY would probably work. You wire to the fuses in the fusebox.
Both of these workarounds probably cost less than a shop repair of the problem
Thanks,
R.
Just to give an update, I have concluded the best thing to do is buy a battery jumper starter. They're cheaper than the $200+ it will cost to get a dealer to fix the problem. But there are some caveats: you have to worry about a jumper starter's operability at the extremes of temperature, see this Consumer Reports article.
There are many other online articles to guide a purchase of a jumper starter. Here are some: a Popular Mechanics article and a CNET article
Regarding the other workaround, I looked at the fuses under the left dash (with a volt meter connected to a ground) and there is one 10 amp fuse, called TAIL that powers "on" (i.e., 12 volts) when the headlights (and other lights) are "on." But I could not identify a fuse that would work as a ground, in other words, is powered "on" when the ignition key is "on," but "off" when the ignition key is "off." So I don't see how I can use the fuse box strategy I cite above. I have a base model, 3 door hatchback and it may be that there is an empty slot that would work as the "negative" fuse. But I don't have the time right now to identify it.
There is another DIY method described here on youtube by Julian Edgar the author of the book Car Electrical and Electric Systems, which is in the public library here. He uses the overhead light as a "ground" for his method. It may be possible to do something like that with the Yaris using the Front Door Courtesy switch that turns the overhead light on and off (depending on whether the driver's door is open or closed). But that would require taking some of the indoor paneling off the car and I don't have time for that right now, even though Chilton's information in the library here describes how to take paneling off the inside of the car.
Here's a youtube video by somebody who did such an installation on a Toyota. It appears to be an older Toyota. Something like this makes a whole lot more sense than paying a dealer hundreds of dollars, especially for the type of people who read this forum.
Any comments from anybody else, including perhaps using the headlights on switch on the steering column as part of a DIY solution will be appreciated.
Thanks,
R.
RMcG is offline   Reply With Quote
buzzer, headlight, reminder
Instrument cluster swapout help JudgeM DIY / Maintenance / Service 39 08-30-2025 09:19 PM
Headlight Reminder and Gauge Illumination not working Nogoldformarfa DIY / Maintenance / Service 0 09-18-2018 12:09 AM
2007 yaris instrument cluster dead and engine won't start dchippowski DIY / Maintenance / Service 2 05-17-2015 11:00 AM
Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback AndyW Willing to Buy by private party 6 12-07-2014 08:53 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
