![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Yeah sounds about right.
Did you change your wheel studs to longer ones? I would like to get some 3-5mm spaces to fix offset on my roh zs. Im going to to change the gear box oil too its a bit crunchy some times going into gears hence Ive been looking for a good lsd unit. Would also pick your brain on gear box oil you prefer? |
| Tags |
| brakes, ncp90, trd yaris, upgrade, vitz rs |
| 5 Lug Conversion | DarkShadowFox | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 60 | 05-18-2018 02:33 PM |
| Rear SE axle beam swap | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 25 | 09-24-2017 11:26 PM |
| 60/40 split rear seat swap question | jayeh | Cosmetic Modifications (Exterior/Interior) | 12 | 10-28-2012 03:07 AM |
| Catback exhausts and rear disc brake conversions | eTiMaGo | Performance Modifications | 59 | 01-04-2009 06:13 PM |
