Old 10-27-2022, 06:16 PM   #1
remcafee
you also did the fronts right? if you panic stop its gonna be unsafe and the car will wrap itself around
Old 10-27-2022, 10:45 PM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
I installed the full rs kit, but even with just the rear it would have been fine, the rears are smaller than standard fronts and have far less braking force. Anyway feels perfectly stable coming to a quick stop at 60km haha but I do need to keep bleeding the system its not quite right yet i can feel air i it sinks a bit if you lay on it so will bleed it a few after a few drives
Compeer is offline   Reply With Quote
Tags
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 03:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-25-2017 12:26 AM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 04:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 07:13 PM
