Old 11-05-2022, 06:48 PM   #1
rajee
Drives: Yaris I
Driverside door lock not working.
Hiiy Folks.
Mine is Yaris 2009 (I'm not the first owner).
I have this issue
Driver side door lock is not working but other side door lock is working and that locks all doors.
( only one side door is locking with key).
Any idea how to solve it.
Materials links and video links.
Thanks in advance
rajee is offline   Reply With Quote
Old 11-09-2022, 02:31 PM   #2
surfajl77
Drives: 2009 Yaris S
Originally Posted by rajee View Post
Hiiy Folks.
I have this issue
Thanks in advance
It's likely the lock actuator. All four of them (actually five if you count the hatch) eventually died in mine and had to be replaced at different points in time.
There should be videos on YouTube.
surfajl77 is offline   Reply With Quote
Old 11-10-2022, 01:24 AM   #3
IndestructibleYaris
you can take apart the lock actuator and replace just the motor for the sake of the stripped gear or whatever stops working, definitely the way to go if you need to save a couple hundred bucks or whatever the difference is
IndestructibleYaris is offline   Reply With Quote
Old 01-01-2023, 05:30 PM   #4
rajee
Drives: Yaris I
Thanks for the info
door, key
Driver side power window not working tobsie DIY / Maintenance / Service 3 05-19-2021 03:02 PM
2015 Yaris Tail Lights Not Working TBowman Third Gen Yaris General Discussion 1 11-20-2016 08:44 AM
Electronics randomly not working - NEED HELP! scoobopdan DIY / Maintenance / Service 5 12-17-2015 07:25 PM
Remote Fob and Stereo Stopped Working after Fuse Change Ruud DIY / Maintenance / Service 6 03-12-2015 07:15 PM
