Old 03-20-2023, 02:37 PM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by mitch9521 View Post
Excuse me? I wanna see this, that sounds awesome. The 1NZ-FE doesn't get the love it deserves in North America.
Theres a company here that specilizes turning them into jet boat engines, they are light wight, reliable and have plenty of torue for the job being designed for a cvt transmission they are perfect for jet boating. https://www.youtube.com/watch?v=mkyk9MPCe-M
Originally Posted by ardianpradana View Post
I have use the RS intake manifold and not using any spacers
have to cut 1 bolt (knock sensor bolt I believe), and cut some coolant line and reroute the line
Nice so the bolt i didnt know I had to move and the hose I had realized was going to need modified, Right now im pretty happy with how the long set up is performing but will in the future try that, did you notice any difference?
Compeer is offline   Reply With Quote
Old 03-21-2023, 04:00 AM   #2
ardianpradana
Drives: White Yaris J M/T
Send a message via MSN to ardianpradana
in real world driving, I'm not noticing any differences
but on dyno, my peak torque shifts 300rpm higher
with stock manifold, the torque drop 25% between peak torque and torque at rev limiter
with RS manifold, the torque drop 19% between peak torque and torque and limiter
ardianpradana is offline   Reply With Quote
Old 03-28-2023, 11:08 PM   #3
Compeer
Fair enough Im liking how mine runs now with the longer manifold, but may still change it up at some point.
Need to dyno my car to find out and won't do that till i have a tune for it.
Going to get a trd cap and leave it upside down just for remcafe! lmfao
Old 03-29-2023, 09:29 AM   #4
Neinris
...Going to get a trd cap and leave it upside down just for remcafe! lmfao
put the extenders on the stock intake...
Old 07-13-2023, 10:59 AM   #5
Compeer
It is! Its crazy torque down low now with the other mods Ive done, very very easy to loose traction now in 2nd and in the wet in most gears lol.
I haven't been active for a while because the car currently is just damn fun to drive, the Throttle body change, intake runner spacer, intake tube and airbox mod are just working so damn well. The car has no dead spot any more and will DURTTTTT all the way from 1.8krpm..give her the beans and it lights up till red line. With only 6400rpm max it feels like I never get off the torque curve. I dont think I will change the manifold to the shorter one as currently she destroys the tires in 1st and 2nd gear and feels like you are actually driving a hot hatch.
Old 07-19-2023, 03:17 AM   #6
sh0rtlife
id kill for the spacer..they dont seem to exist here.....all said mine pulls real good for everything else ive done
Old 08-03-2023, 05:06 AM   #7
Compeer
Its the EGR plate that I used JB weld on to seal the holes on. where ever you find the shorter manifold you find the egr plate, it bolts on to our block normally, just means you have to loose the top engine cover.
1ZZfe mod info darkMINI Performance Modifications 21 07-13-2011 12:41 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
