swap out the whole engine..your likely on an uphill battle with it and the headgasket did more than just the headgasket ie cooked the rings, glazed the cyl's. cooked the valve guides and seals....basicly just becuase the head gasket was done...doesnt fix everything else that went with it/because of it
ive seen this kind of thing before with hondas...and the owner assumes it just needs a head gasket, thing is its rare to have a head gasket go and not need to rebuild the ENTIRE head, more often than not its possible to get warping on the block as well....and then of course youve got the excessive heat on all of the sensors, coolant/oil mix that gets into EVERYTHING and is neerly impossible to clean it all out without replacements |
| Tags |
| fuel economy, head unit, overhaul, smoking |
| Found : head gasket oil leak on 2 used 2010 YARIS ... | Hershey | DIY / Maintenance / Service | 200 | 04-23-2013 11:22 PM |
| Could the 07-08 yaris s front lips actually fits 2010 yaris? | Adward10 | Cosmetic Modifications (Exterior/Interior) | 3 | 03-18-2013 12:06 AM |
| Please help!! Just totalled my 2007 Yaris. Need to buy 2010 model!! | 12490 | Australia | 13 | 11-02-2010 04:25 PM |
| FE Turnaround: Disappointment to Satisfaction, 2010 Yaris. Almost +50 MPH. Thank You! | STC | Fuel Economy Forum | 12 | 04-16-2010 11:21 PM |
