Old 10-03-2023, 03:59 PM   #7
BLH
Drives: 2007 Yaris Sedan
Videos I saw seem to agree.
Clamp is in a corrosion zone.
Hard to remove due to the corrosion.
The pipe is also known to corrode.
I would also expect a Cheek Engine Light and codes. If the evaporation system tests detected any leaks.
My 2007 runs the test around six hours after turning off the car. Sometimes you can hear the test pump running the test.
BLH is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 01:44 PM
