Old 11-14-2023, 07:58 AM   #1
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
zinc oxide rust inhibitors.
I had a 20 year old Geo Metro and was about to spray the green oxide inside the frame channels and kick boards. I crunched the car before I did the frame coatings. It was a shame the car had a full urethane suspension abd big swaybars. It handled like it was on rails in the canyons here in L.A. / Ventura counties. Hear is a link to the interior frame coatings.
https://www.eastwood.com/eastwood-in...z-aerosol.html
Originally Posted by Billiam View Post
Yes...they rot from the inside out. Don't be fooled by looking at the outside and thinking things are fine. Every time I rotated my tires, adjust brakes, etc I always checked things out. It never occurred to me that anything was wrong. It all looked fine. It wasn't until it actually broke that I realized there was a problem that had been lurking internally....probably for years.
Calrenman is offline   Reply With Quote
Old 11-15-2023, 02:24 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
That's very similar to the Liquid Wrench Rust Inhibitor that I used. The problem is, dirt and debri accumulate in the trailing arms over time. That material tends to get wet and stay wet. The corrosion will always effect the weak points first....that being the welds. So if someone is going to apply any type of rust inhibitor to the inside of the trailing arms I suggest they rinse them out thoroughly first and let them dry for a couple of days
If you want to enjoy your car, stay off of the internet.
Old 12-02-2023, 08:55 PM   #3
kobe52
Drives: Yaris
good headsup.
do you have a part number/s for the scion replacements?
kobe52 is offline   Reply With Quote
Old 12-03-2023, 09:26 AM   #4
Billiam
Originally Posted by kobe52 View Post
good headsup.
4211052332
How to set up rear window wash sprayer? Be_Jammin DIY / Maintenance / Service 0 03-13-2016 06:40 PM
Handling changes from rear hub spacers and minor concern. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 07-10-2009 09:07 PM
