Old 01-01-2024, 08:38 PM   #1
ltwargssf
Drives: yaris
Cold Start ticking noise, lifters?
So when it gets really cold my engine starts to tick a few seconds after starting it then goes away. It seems to be coming from the valvetrain like a lifter isn't priming. Is this a common issue? It doesn't rattle right away like a cam adjuster issue, the video below you can hear the metallic tick starting a few second after the engine is on( When I put my hand on the engine), I cut it a bit short but it goes away shortly after I ended the video.
There is no noise unless it gets just below freezing outside and sitting overnight. On warmer days it starts very smoothly with no ticking.
https://www.youtube.com/shorts/jJP-ZAewyas
ltwargssf is offline   Reply With Quote
Have engine knocking noise, assume it's lifters, but... just1witness DIY / Maintenance / Service 5 04-10-2023 04:54 PM
Metallic noise after starting on cold morning CrimsonEclipse DIY / Maintenance / Service 4 11-20-2022 05:46 PM
04 Echo won't cold start....... Ronnie V DIY / Maintenance / Service 3 03-31-2022 07:29 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
longer turn over on start w/ cold weather manborn General Yaris / Vitz Discussion 20 02-04-2007 11:35 PM
