Old 05-08-2024, 02:39 PM   #4
remcafee
the input shaft bearing keeps the geartrain aligned, so if its starting to wobble around, the center line will be messed up, you could eventually snap the shaft or damage gears
Transmission issues after 1nzfet swap Huevito General Yaris / Vitz Discussion 2 03-04-2024 12:02 AM
About to replace the transmission fluid on an automatic 2008 yaris with 172kms jessesYaris General Yaris / Vitz Discussion 6 09-23-2021 04:51 PM
Transmission oil? jamesxl DIY / Maintenance / Service 3 04-11-2016 10:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
