Old 05-16-2009, 05:03 PM   #1
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Well the CEL finally disappeared and it ran great for about a mile. and then this
Fuck this throttle body. Put the stocker back on and it is running great.
Old 05-20-2009, 09:00 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
dude! i was about to put it on! now im gonna have second thoughts or get garm's! jeez...i think there HAS to be something we're missing...a hidden variable thats affecting some of us...
Old 05-16-2009, 06:20 PM   #3
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Whaaaaaaaaaaaaaaaaaaat? Please explain what happened. I'm scared, I'm scared for my life now.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-16-2009, 06:35 PM   #4
jkuchta
Drives: 2007 Yaris hatch (red)
So what went wrong? Do you know what the CEL code was?
Please tell me step-by-step how you installed the 1zz TB so we can figure out what went wrong. I've been running mine without fault for a few months now...there's got to be something simple that can be fixed and will clear up the whole problem.
And eii, if you want to go for a ride in a yaris with the 1zz tb install that was done correctly, PM me.
jkuchta is offline   Reply With Quote
Old 05-18-2009, 01:29 AM   #5
PHXDEMON
PHXDEMON's Avatar
CEL was gone. Car completely died and wouldn't even idle. Start it up and it woul ddie instantly. I used the original gasket plus gasket maker, I did the coolant bypass, I did the chip swap. I did everything it just didn't work out for me
Old 05-18-2009, 01:35 AM   #6
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
That could be pretty much the 1ZZ T/B itself being the problem, try another different 1ZZ T/B or try the 2AZ-FE 2.4L T/B.
remember! failing is the beginning of success, it wasn't easy for me either
Yaris T-Sport. is offline   Reply With Quote
Old 05-20-2009, 09:13 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
doesnt sound like the TB unless a wire snapped somewhere.
Old 05-20-2009, 09:31 PM   #8
PHXDEMON
PHXDEMON's Avatar
Stocker works flawless though so it isn't a wiring issue.
Old 05-21-2009, 02:01 PM   #9
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
i would say come over and we can try it again and i can follow you and swap it back if it f's up again
thats if you still have it
http://www.4055design.com
Old 05-26-2009, 10:58 AM   #10
eii
Rides canyon walls
eii's Avatar
Oh I was just kidding, hehe . I based my install on the guide post you made earlier in this thread (thanks btw) so I'm sure I did it correct. I just get that < 1 minute 2.5k-ish cold idle start. Other than that it works great, I was just wondering what happened to demon. I just did the coolant bypass this morning, its more responsive and I definitely feel some more power. Cool stuff
Old 05-16-2009, 06:56 PM   #11
kustom play
Drives: 07 liftback
yea thats crazy my CEL went off and its been running great!
Old 05-18-2009, 01:35 AM   #12
jkuchta
Bummer...
Do you know what the code for the CEL you were getting was? It may provide some clues as to what caused your problem.
Old 05-20-2009, 08:35 PM   #13
bieniman
bieniman's Avatar
Drives: vitz rs 1500 2001
Guys,
I've been following this mod for a while now,
If I'm correct the newer yaris models have electronically controlled TB. Well, I looked under my hood and see sort of like a cable running from the pedal to the TB, I can rev my engine by turning this swivel.
bieniman is offline   Reply With Quote
Old 05-20-2009, 09:12 PM   #14
AlexNet0
AlexNet0's Avatar
Originally Posted by bieniman View Post
Guys,
Yes, this mod only applies to the Drive by wire system that is in the ( i believe) '05 and newer
Old 05-20-2009, 09:33 PM   #15
PHXDEMON
PHXDEMON's Avatar
Guys,
I'm not 100% positive on this but the scion xa/xb owners have done a swap with an older 1zz throttle body which is drive by cable like yours. check the forums @ scionlife.com you should be able to dig up more info.
Old 05-20-2009, 08:38 PM   #16
bieniman
bieniman's Avatar
O yeah forgot to ask.
Can I do this mod also to my , Vitz Rs 2001?????
Old 05-21-2009, 12:53 AM   #17
MGargano
Drives: 2009 Yaris Hatchback
The chip swap was working fine for me... no CEL or oscillation... until I had to disconnect the battery to swap the steering wheel. Once I reconnected, oscillation & CELs galore.
MGargano is offline   Reply With Quote
Old 05-21-2009, 03:10 AM   #18
jkuchta
What codes are showing up?
Just saying you have a CEL is kind of worthless unless we know what the code is. It could be just a case of needing to adjust the idle set screw, or a number of other things.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
