#1 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
That will be me lol I just bought the 1zz tb like a few days ago specifically to add it to this manifold. I have the big 3 bolt ons as well so I think I will be seeing really nice gains
#3 | |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
#4 |
Form>Function
lol Ill keep you updated man
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
I know there is a thread on the 1zz TB. What is the PnP part number on the 1zz TB for the Yaris with DriveByWire?
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#6 |
play every day
The part number on my 1ZZ is:
22030-0D030 And the difference in throttle response is night and day... ![]()
#7 |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
where do I get this throttle body without paying eleventy billion dollars?
presumably you guys (with them) are sourcing off ebay or used places? W |
#8 |
play every day
#9 |
![]() ![]() Drives: 2012 Yaris LE Join Date: Oct 2012
#10 |
^ That's about right for a really clean one. Dirty/worn/sketchy would be the $60-70 range.
#11 |
Form>Function
I bought one used off a member for 55 but it needs a real good cleaning, id also like to Neo chrome it so ill be reinvesting money into it.
#12 |
![]() ![]() Drives: 2010 Yaris sedan silver Join Date: Jul 2012
I'm sorry if this has been asked. Is that tb a direct bolt on for our stock intake manifold?
#13 | |
play every day
A 1ZZ will bolt on because the stud holes are the same as stock at 60mm square, but the diameter of the stock O ring gasket is too small to seal the larger 55mm bore, and I don't believe that the larger butterfly when opened will clear the stock hole either. |
#14 |
Thanks for the info Tooter.
#15 |
I bought a sketchy looking one (will need a cleaning) for $55
quick question / do I (should I) transfer the electronics from the old to the new? (looks interchangeable?) or is it simply plug and play? |
#16 |
play every day
I switched mine just to be sure, but you could try it first with the 1ZZ chip.
But I do know this from personal experience... it will NOT work unless you chip out the epoxy and turn the allen key head idle screw counterclockwise about a turn... ![]() It's that tiny screw just above the upper left hand throttle body stud... and don't strip it. |
#17 |
Form>Function
@tooter so the tb installation requires a larger o ring, possible chip swap, removal of epoxy, and adjusting the idle set screw? I skipped anything about the butterfly valve needing space since Im sure MI thought of those dimmensions with the new manifold design since they wanted to be able to combine the two for even better performance.
#18 | |
play every day
![]() You want the flow to be compatable with the larger throttle body anyways. |
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 11:58 AM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
