Old 02-02-2013, 11:41 AM   #235
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
@tooter so the tb installation requires a larger o ring, possible chip swap, removal of epoxy, and adjusting the idle set screw? I skipped anything about the butterfly valve needing space since Im sure MI thought of those dimmensions with the new manifold design since they wanted to be able to combine the two for even better performance.
You're absolutely right. A larger butterfly likely won't clear a smaller stock bore, so it's a simple matter to make a larger bore and larger diameter gasket to fit both throttle bodies.
You want the flow to be compatable with the larger throttle body anyways.
Old 02-02-2013, 12:03 PM   #236
I got PM's that the thread has become confusing, and I can't prune it, so.....
For those following along, please note that posts from #231 on (Silver Streak) refer to swapping a 1ZZ throttle body onto a STOCK manifold, and are not about the MICRO IMAGE manifold.
Our manifold comes with the O-ring, is a direct bolt-on, and requires no modifications to use either a 1ZZ throttle body or your stock 1NZ throttle body.
Old 02-02-2013, 12:05 PM   #237
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
awesome ^^
sorry to get off topic
Old 02-02-2013, 07:14 PM   #238
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Awesome! I'm so excited to see the new version of the manifold. I've already got my information in and am on the wait list. I can't wait to get this and install it with my 1ZZ throttle body.
4/20 NEVER FORGET is offline   Reply With Quote
Old 02-02-2013, 08:14 PM   #239
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
now to get Garm to confirm the intake kit that comes with the 1zz throttle body and a set of 1zz injectors. hint hint...
Old 02-02-2013, 08:18 PM   #240
4/20 NEVER FORGET
Why would you need 1zz injectors? I mean, I understand that they are a larger injector, but unless you are going turbocharged/supercharged, what's the point? Seems like it would be a bit overkill for NA.
Old 02-02-2013, 08:46 PM   #241
1.5
Form>Function
1.5's Avatar
Not necessarily, a large TB and upgraded manifold will lean out the mixture. I'm sure the maf will see more air coming in and increase the fuel delivery but if the stock injectors can't pump anymore, then the 1zz should meet those needs. More air + more fuel = more explosions = more power.
Old 02-02-2013, 09:00 PM   #242
^ I don't see this manifold + 1ZZ TB requiring larger injectors.
Dynos will tell, but it certainly doesn't need them with the stock TB - as shown on the dyno.
Old 02-02-2013, 09:20 PM   #243
4/20 NEVER FORGET
Not always. I've dyno-tuned two Hondas I've owned in the past with VAFCs and wide-band, both with many bolt-on mods and larger throttle bodies. Naturally aspirated, with stock injectors, EVERY TIME I made power by reducing the fuel injector pulse from stock. You'd be surprised what the stock injectors are capable of, every time I've put a car on a dyno with a wide-band o2, the car was running rich and I ended up taking away fuel to make power. In the case of my H22A-swapped Civic, I made 9 hp and 10 tq at the wheels with just a VAFC and some dyno time. The fuel and air mixtures need to be in balance, too much of either one isn't a good thing.
More air + balanced fuel = more power
More air + too much fuel = less power, lower mpg
Old 02-06-2013, 03:30 PM   #244
3cyltrbo
anyone get theirs yet?
pictures? / install impressions?
sound? / buttdyno?
Will
3cyltrbo is offline   Reply With Quote
Old 02-06-2013, 03:33 PM   #245
1.5
Form>Function
1.5's Avatar
not yet but I am dying waiting lol
mines in finishing right now
Old 02-06-2013, 04:56 PM   #246
tooter
play every day
tooter's Avatar
Can't wait to actually see one!
Be sure to post lots of pictures. If yours is only being finished now, they must be shipping directly from Golden Eagle. Isn't there anyone else here who actually has one?
Old 02-06-2013, 04:59 PM   #247
1.5
Form>Function
1.5's Avatar
well they only got 3 and mine is one of those and its actually being custom plated... I couldnt keep it a secret anymore lol so its taking a while
the other 2 may have shipped out already unless maybe garm is keeping one to put on his hatch
Old 02-06-2013, 05:58 PM   #248
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
i really cant imagine the need for bigger injectors for this N/A setup. Your better off getting your car tuned.
Old 02-06-2013, 08:15 PM   #249
4/20 NEVER FORGET
I've tried calling and emailing but don't have a date as to when I'm getting one shipped to me yet. I WANT so badly. When I do get one I'll be sure to post lots of pics and try and get it to a dyno after install.
Old 02-06-2013, 08:22 PM   #250
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Forgive me for not wanting to read through 14 pages of posts....but is there any dyno data on this intake manifold to show the gains? thanks.
Captain Slow is offline   Reply With Quote
Old 02-06-2013, 10:20 PM   #251
1.5
Form>Function
1.5's Avatar
Originally Posted by tooter View Post
Ok... I see the 7 foot pounds of torque, and almost 5 horsepower...
...and hoping that Garm will post some pictures.
Here you go
Old 02-06-2013, 10:57 PM   #252
No. We are inspecting every manifold closely, and we have to assemble the included installation kit to go with it. They are all coming from us. Sorry for the delay on the first few; the batch of breather hose that came (that will be included) was not up to our standards.
We now have five going out by Friday; I'm sure there will be some feedback by next week sometime.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
