Old 10-31-2018, 05:55 PM   #253
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
[QUOTE=06YarisRS;818414]
Ok, I see what happened here, When I did my swap I thought I was clear that I used all COROLLA parts. So my corolla plug has no pin 10, just the 9 that I have been telling everyone.
Now because you have an xD harness the wires are different there at C29, You need to reconnect the blue wire.
Sorry for the confusion, I have no idea whats up with Brushhforhires swap and if he ever figured out this before the crash.
Old 10-31-2018, 07:49 PM   #254
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Hi Adam and Tom.
I reconnected the blue wire to the harness and unfortunately I still have the P2770 code appearing.
Old 10-31-2018, 07:53 PM   #255
06YarisRS
[QUOTE=ArmstrongRacing;818421]
Thanks Tom. You were definitely clear about using Corolla only parts. It's my misinterpretation or failure to follow directions I suspect. I'm not giving up hope and really appreciate all the help, but I am beginning to wonder if I should have undertaken this project in the first place. I'm willing to do whatever it takes to fix this, but it may be too far beyond my skill level.
Old 10-31-2018, 08:21 PM   #256
atomic_hoji
Drives: 2018 Yaris SE 5MT
Hi Adam and Tom.
May sound silly, but did you remember to clear all the codes? My recollection is that some OBD2 codes will stick the MIL/CEL on even if the condition no longer exists..
And is this the only code you're getting now?
-- Adam
Old 10-31-2018, 08:21 PM   #257
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
No way man, you've got this! You've already done all the hard work, why stop now? If you've still got access to the EWDs, go over them again and double check what wires go where.
File Type: jpg l-33429-hey-you-yes-you-you-can-do-it.jpg (101.1 KB, 74 views)
Old 10-31-2018, 08:45 PM   #258
ArmstrongRacing
Data doesn't lie
If clearing the codes does nothing, ground the brown wire next to the blue one you just fixed. That’s pin 9
Old 10-31-2018, 08:56 PM   #259
06YarisRS
-- Adam
Hey Adam. Yes, it's the only code I'm getting now. I was also getting a P0977 (shift solenoid "B" control circuit high), but that seems to have gone away by itself but that happened before re-connecting the blue wire. I have cleared the code with Torque Pro and it turns the MIL off, but it comes back on basically as soon as I turn the ingition on. I'm wondering if the speed sensor harness I made is having anything to do with this. I'm sure my wiring was right and the pins all went in nicely. Also, the CA2 connector is properly seated.
The MAf codes are all gone, but I've only run the car for 5 - 8 minutes at a time. My ac compressor does not sound good and no one had any PAG oil around here.
I thought that maybe the other DTCs were being set by low voltage due to my no-charge situation (which remains btw) but I've connected it to my van's battery. My multi meter shows 13.8 volts with the battery jumpered, but as soon as I take off the battery cable, it drops to 10ish volts and then keeps dropping.
Old 10-31-2018, 08:57 PM   #260
06YarisRS
I will definitely try that Tom. Thank you.
Old 10-31-2018, 09:01 PM   #261
06YarisRS
Haha, thanks Sam! I think I'm just a little tired now and a little disheartened. I've had quite a few consecutive late nights working on this project. I guess I'm wondering if some combination of parts/factors will make this project not possible. If I know that it definitely can be done (aka, it's possible electrically/mechanically and they there are no limitiations - other than my own, LOL - that make it impossible), then I'd feel better. I just don't know enough to know this for sure. It will probably turn out to be something that I missed and I'll slap myself for being stupid or careless. LOL. I do very much appreciate the encouragement.
Old 10-31-2018, 09:10 PM   #262
I rechecked Brishforhire's thread and your grounded wire is the exact same as his. Not sure about why the ewd's show it should be connected.
Have you checked if your ground is good? That's the first thing to do and then check your wiring on your ground is good
I'm not great with ewd's and I can't help much for the a/t swap other then what is in other threads
Old 10-31-2018, 10:22 PM   #263
atomic_hoji
Down to 1 OBD code is good progress! I've had mine on the road for months and there's at least 1 or 2 at any given time...
So I had a look in my 2018 Yaris manual, but the P2770 DTC (code) isn't actually listed - I either didn't download it, which is possible, or it isn't in this service manual.. The manual you had/have access to may have something in it though? Check in the auto transmission section of the manual(s) under the troubleshooting or control sections, maybe it will give you some more information. Maybe Tom knows more as he's more familiar with the automatics, but I think the SLU solenoid might be for torque converter lock-up? In which case, given the code you're getting, I think you're chasing the right rabbit hole...
I did have a peek through the manual though and it looks like on the transmission itself there is a sub-harness from the connector that runs to the shift solenoids and components on the transmission. Might be worth having a check of those connectors that the wires are good - didn't get snagged on anything moving the 1NZ out / 2ZR in, connectors are clean and seated well. It's easy to do quick - ok, maybe not 'easy' since it's in the car..
Another idea would be to disconnect the battery, disconnect the engine harness connector at the ECM and the connector C29 at the automatic transmission and do a continuity / resistance check. So, basically get a multi-meter and stick a probe in the ECM pin and the other in the corresponding C29 pin and do a. a continuity check (a connection, multi-meter usually beeps) and b. a resistance measurement to see if you have high resistance in the wire - if you do, there might be a bad solder/connection. Work your way through all 9 wires and confirm your electrical connection is solid. It's a bit tedious, but maybe worth a look if the other ideas don't solve your problem.
A/C compressor hopefully survives, but sounds like it might need oil if you hadn't added any. A Ideal Supply / NAPA or similar should be able to order a small container of PAG for you. I recall it not being cheap given the tiny size of the container.. lol
Is it your Yaris' battery that's low? I might be mis-understanding, but if you jumper it from the van and it seems to charge with a good voltage, but you remove the good battery out of the loop and it drops, that seems like the Yaris' battery is hooped.. ?
Keep at it buddy, you're almost there... that first drive out you'll be cautious, listen for problems, nervous... then you'll get comfortable and open it up - and that's when the smiles start.
-- Adam
Old 10-31-2018, 10:23 PM   #264
ArmstrongRacing
Data doesn't lie
Brushforhire's wiring was obviously wrong, not sure why he never disclosed that. He was the first 2zr + auto swap to use the xD auto harness. I've had Pin 9 posted in all of my write-ups and I don't understand why he did Pin 10 and never mentioned an issue.
I guess we will find out
Old 10-31-2018, 10:59 PM   #265
06YarisRS
You guys are amazing! I looked at the wiring diagrams again and SLU - (pin 9), as mentioned by Tom will get grounded tomorrow. P2770 refers to "An open in the shift solenoid valve SL circuit is detected". To me pin 9 is SLU - (or ground), so this makes sense that if not grounded, there would be an open circuit, thus setting the code. Feel free to tell me I'm full of it, LOL! I will report back tomorrow as to how this works. I am optimistic about this. I do have one question, though. Are these circuits protected, in other words, will damage be prevented by the ecu or does one run a risk of frying/damaging something by changing wires around?
Old 10-31-2018, 11:37 PM   #266
ArmstrongRacing
Data doesn't lie
... will damage be prevented by the ecu or does one run a risk of frying/damaging something by changing wires around?
No, grounding the plug wires wont cause damage. However, if you were to ground the wire in the harness from the ECM on the positive side of the solenoid something bad may happen. That would be a direct short to ground!
Old 11-01-2018, 05:56 AM   #267
Well then, that makes more sense. I assumed his thread was all correct and never had time to look through any others
Old 11-01-2018, 06:27 AM   #268
06YarisRS
-- Adam
Thanks Adam. This sub harness you mention intrigues me. Here is a pic of the top trans plug. It seems to have mositure and dirt in it. Could this be causing a problem or are these pins completely isolated form eachother?
Old 11-01-2018, 05:53 PM   #269
atomic_hoji
^ could probably use a quick blast with some electrical cleaner, but the terminals themselves look decent from the picture; nothing corroded or mangled. Those terminals are pretty separate when the connector is pushed together, I wouldn't imagine it's causing a problem, but easy enough to give it a quick clean-up.
-- Adam
Old 11-01-2018, 06:34 PM   #270
06YarisRS
-- Adam
Well that's good Adam. Thanks! I took my alternator in and had it tested. It passed with flying colors. I was actually hoping it would fail so I could just buy another, bolt it on be good to go. Haha. So it looks like I have another electrical problem to try to fix. A bit back in thread, Tom gave me some guidance that I will follow. I'll bolt the alternator back on, and try Tom's suggestion. I'll also ground the pin 9 wire and check to see if the P2770 goes away. If neither works, I think I may have to step away from this for a few days. The progress has been good so far - I'm really glad it started, lol - but I could use another 'win' soon. I need to convince myself that all obstacles are able to be overcome.
Here is the alternator print out
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
