Old 10-31-2018, 07:53 PM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
[QUOTE=ArmstrongRacing;818421]
Ok, I see what happened here, When I did my swap I thought I was clear that I used all COROLLA parts. So my corolla plug has no pin 10, just the 9 that I have been telling everyone.
Now because you have an xD harness the wires are different there at C29, You need to reconnect the blue wire.
Sorry for the confusion, I have no idea whats up with Brushhforhires swap and if he ever figured out this before the crash.
Thanks Tom. You were definitely clear about using Corolla only parts. It's my misinterpretation or failure to follow directions I suspect. I'm not giving up hope and really appreciate all the help, but I am beginning to wonder if I should have undertaken this project in the first place. I'm willing to do whatever it takes to fix this, but it may be too far beyond my skill level.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
