Old 05-07-2009, 01:30 PM   #1
Originally Posted by nickhjort View Post
Damn that sucks dude. I'm sorry that it's not able to be done with your car. What if you get an ECM from a yaris like ours? Or will that even work...CTScott?
Not with his transmission. Also, even a used ECM would be more expensive then the aftermarket cruise kit.
Old 05-07-2009, 11:09 PM   #2
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I see...good to know :)
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-08-2009, 02:38 AM   #3
regal
is it possible to order the side cover piece from the factory with the hole already there? I am sloppy with a drill and dremmell and don't want a hack job.
Old 05-08-2009, 08:08 AM   #4
Cover, Steering Wheel Boss, Lower: 45184-52130-B0
This is for one that has the hole for factory cruise control.
Old 05-09-2009, 10:23 AM   #5
nickhjort
nickhjort's Avatar
Damn man that's awesome...PM sent.
Thanks so much for all the help with this project. It's not so bad being the guinea pig on something when you have so much knowledgable help on the subject. Hopefully we can get this thing hooked up and write up a nice DIY for the other "cruise control-wire-missing" drivers here :)
My Car Rules!
Old 05-09-2009, 10:36 AM   #6
mrbond
mrbond's Avatar
Alright, so just to sum it up for the stalk usage: I remove the airbag, install the stalk like in that Matrix link, then run a wire from the D connector to a ground point, and then the other wire straight to pin #40 in the ECM?
Do I mess with A21, or do I just do what I wrote in the above paragraph? (and this is all just if I don't bother with the clutch switch just yet)
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 11:32 AM   #7
Correct.
Remember that in order to even test it, you will need to bypass the clutch switch at the under hood fuse panel connector.
Old 05-09-2009, 11:37 AM   #8
mrbond
mrbond's Avatar
^ right, you said to jumper it to the white wire 2 pins over? What do you mean by jumper?
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 01:13 PM   #9
Basically, make the connection. Since it is temporary, until you get the switch, I would just shove a stiff piece of wire from the blue to the white.
Old 05-09-2009, 03:09 PM   #10
mrbond
mrbond's Avatar
nickhjort, did you find any connector for the wiring to the clutch switch? Been searching for it for a few hours and haven't found anything. I believe that only the 09+ mt Yarii have that plug just hanging there...
Also, what is the function of the white wire you jumped the blue clutch switch wire to? Did you just do like what CTScott said and stuffed one wire into both pins?
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 04:30 PM   #11
nickhjort
nickhjort's Avatar
Yeah basically I just used a thick guage wire I had laying around, that just happened to have a fuse on it, and just stuck it in there. You probably don't need the fuse, but what the hell...you can never have too many fuses right :) And no I didn't find the clutch switch connector under there either. I am still going to buy the stock switch though and just wire it to where I have the jumper in the fuse box. Basically what the switch does is acts as the jumper wire...only it's a reversed switch. So when you hit the clutch it kills the circuit (just like if you were to pull the jumper wire while using cruise control) Here's some pics of my jumper. Also make sre you put some spade connectors on the ends of your wire. They fit in there perfectly, nice and tight to ensure it doesn't come loose.
Hope it helps
My Car Rules!
Old 05-09-2009, 04:31 PM   #12
nickhjort
nickhjort's Avatar
PS... Make sure whatever you use as a jumper will fit under there whenever you put the fuse box cover back on :) Mine just barely fits.
My Car Rules!
Old 05-09-2009, 05:19 PM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
so thats all you have to do to bypass the secondary clutch switch for the MT?
Old 05-09-2009, 05:26 PM   #14
mrbond
mrbond's Avatar
Wow, that actually cleared things up a lot, thanks!
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 05:31 PM   #15
nickhjort
nickhjort's Avatar
Yup that's it and everything to bypass the MT clutch switch. Now if you are using cruise control and you hit the clutch the engine will rev like a mofo since there's no switch to stop it...so don't hit the clutch! Unless you wanna blow shit up
My Car Rules!
Old 05-12-2009, 08:38 PM   #16
AlexNet0
AlexNet0's Avatar
so instead going through the hassle of buying the secondary clutch switch for the cruise, I should be able to use those two jump points in the fuse box and wire a momentary button to shut it off? and then I can just press the "on" and "set" to start the cruise again?
Old 05-12-2009, 08:43 PM   #17
Actually, just press set again (or resume if you do the four button method). Only on/off or the keyswitch completely clear cruise mode.
Old 05-12-2009, 08:54 PM   #18
AlexNet0
AlexNet0's Avatar
yeah, I bought the OEM stalk
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
