Old 05-09-2009, 05:19 PM   #289
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by nickhjort View Post
PS... Make sure whatever you use as a jumper will fit under there whenever you put the fuse box cover back on :) Mine just barely fits.
so thats all you have to do to bypass the secondary clutch switch for the MT?
Old 05-09-2009, 05:26 PM   #290
mrbond
mrbond's Avatar
Wow, that actually cleared things up a lot, thanks!
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 05:31 PM   #291
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Yup that's it and everything to bypass the MT clutch switch. Now if you are using cruise control and you hit the clutch the engine will rev like a mofo since there's no switch to stop it...so don't hit the clutch! Unless you wanna blow shit up
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-09-2009, 05:47 PM   #292
nickhjort
nickhjort's Avatar
Also I'm probably going to try to make my own clutch switch, seeing as it's only a momentary switch held down bt the clutch. I'd rather spend another 2 bucks on the switch then 19 at the dealer. I'll post pics once I finish it.
My Car Rules!
Old 05-12-2009, 06:16 PM   #293
mrbond
mrbond's Avatar
So...theoretically I wouldn't even need to remove the dashboard if I'm using the stalk. If I reuse a ground point on the driver's side kick panel next to the hood release, and just thread all the necessary wires through the firewall, then that's the end of that. Now, this is exciting.
- A Toyota Yaris
- A whut Yaris?
Old 05-12-2009, 08:07 PM   #294
Definitely don't remove the dash, since the junction point under there is not populated. It's just a straight run from the stalk connector to the ECM.
Old 05-12-2009, 08:14 PM   #295
mrbond
mrbond's Avatar
By the way, if anyone has the clutch switch on hand, could you post a picture of the connector? I believe I may have found the necessary wire plug. It was taped up with a bunch of other wires by the clutch pedal, so....
- A Toyota Yaris
- A whut Yaris?
Old 05-12-2009, 08:31 PM   #296
The connector is a two pin one with a black and a blue wire.
Old 05-12-2009, 08:38 PM   #297
AlexNet0
AlexNet0's Avatar
so instead going through the hassle of buying the secondary clutch switch for the cruise, I should be able to use those two jump points in the fuse box and wire a momentary button to shut it off? and then I can just press the "on" and "set" to start the cruise again?
Old 05-12-2009, 08:43 PM   #298
Actually, just press set again (or resume if you do the four button method). Only on/off or the keyswitch completely clear cruise mode.
Old 05-12-2009, 08:54 PM   #299
AlexNet0
AlexNet0's Avatar
yeah, I bought the OEM stalk
Old 05-12-2009, 09:54 PM   #300
mrbond
mrbond's Avatar
Well, I found an unused wire plug, but it's clearly the wrong one. I wonder what this one's for?
Anyway, AllexNet0, I'll be installing the stalk on sunday hopefully. I'll take a bunch of pictures for each step of the way. And we'll see what happens with the clutch switch wiring that nickhjort was talking about.
- A Toyota Yaris
- A whut Yaris?
Old 05-15-2009, 06:08 PM   #301
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Hey nickhjort, did you ever figure out that homemade clutch switch? I think a lot of us are anxiously waiting to see if that works! Let us know asap thanks!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-15-2009, 11:46 PM   #302
nickhjort
nickhjort's Avatar
Yeah tomorrow I will be "frankenstein"ing it together. I haven't had time yet, but tomorrow I will hopefully have it done, and I will also mock up an exhaust idea I had. I will take pictures of both :)
Motorcycle Exhaust on a Yaris!
My Car Rules!
Old 05-16-2009, 05:35 PM   #303
nickhjort
nickhjort's Avatar
Pics for now... I will take more in an hour or so when I get it put in...it's raining like a mofo here now...
This is my switch I bought at radio shack. You get four in a pack for 3.59 I think.
Aluminum bracket, switch and bolt that replaces stock clutch switch.
My Frankenstein (It's ALIIIIIIVE!!!!...almost)
Just make sure you have a SPST switch that is normally open...not closed. Also make sure it is long enough to touch the little black plate you see in the picture. I think mine is barely gunna work. If not I will probably epoxy something onto the end to make the button part longer. We'll see in a few.
My Car Rules!
Old 05-16-2009, 06:09 PM   #304
nickhjort
nickhjort's Avatar
Well the switch was just barely too small. So JB Weld time...
I used a cap from a can of liguid wrench :) Now it truly is a frankenstein haha. But it's all good. Nobody can even see it unless they stick their head under the dash. Anyway more pics to come soon when it's installed in the car.
My Car Rules!
Old 05-16-2009, 08:52 PM   #305
nickhjort
nickhjort's Avatar
Alright peeps, it's in. It works so far when hooked up to the meter. Tomorrow I'm gunna wire it in and test her out. Now all I'm waiting for is the led "module", courtesy of CTScott then I'll be all set
My Car Rules!
Old 05-17-2009, 03:53 PM   #306
Nice job with the DIY switch. Hopefully this week I'll be able to ship you the module for driving the LED.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
