Old 12-16-2013, 02:24 AM   #325
nookandcrannycar
Even after going through the nightmare of replacing the broken one, I really don't blame this on Toyota as much as I do on the people who choose the Winter chemicals to use on our roads.
The difference in corrosion between the 2007 100K+ mile California Yaris that I recently parted out and this 2007 70K mile Ohio Yaris is incredible.
Recently I was chatting with a guy who works for the CT highway department and he was telling me about how bad the trucks that spray the road chemicals disintegrate in a single season, and it is just plain scary.
Wow. I wonder what the California Department of Transportation uses for 'winter road treatment' ? Unlike CT, OH, etc., relatively few well traveled roads in densely populated areas that would need any Winter treatment. I would think the main concern would be the Interstate Highways (plus U.S. 50) where traffic has to go over a good size mountain range/pass to get to another state.
Old 12-16-2013, 02:38 AM   #326
nookandcrannycar
Currently on the 'story wheel' on the Yahoo home page ----- 2014 Audi R8 Convertible and a fleet of 1984 Audi 4000 Quatros having fun on 600 acres --- in the snow. I wonder what the fleet of '84s look like underneath?????
http://autos.yahoo.com/blogs/motoram...173509726.html
Old 12-16-2013, 11:12 PM   #327
Viperoni
Drives: 2005 Toyota Echo
I posted in one of these control arm bolt threads, soon after I got my Echo, and called out an OP on them. Now I've got my tail inbetween my legs. I've had a few bolts snap on me that should not have ever snapped - the worst two being the thermostat housing *studs*.
Basically it's horrendously cheap quality metal.
Anyone else have trouble with bolts snapping due to poor quality metal on their Yaris?
Given my experience with my Echo, and then reading this thread and the TSB's out there for the issue... is coming close to ticking the Yaris off my "next car" list...
2006 Saturn Ion Redline
Old 12-17-2013, 02:58 AM   #328
nookandcrannycar
I would probably feel differently if I lived in a Winter climate like yours, but I'll probably be willing to give the Prius C a shot after (hopefully) many more miles have elapsed on my Yaris.
Old 12-17-2013, 07:08 AM   #329
Viperoni
Everybody's said that, but this is the only car I've had this "weak bolts" problem with, and I've been through a few cars... and have done a ton of work on them too.
Probably the best example was with my old 92 Nissan NX2000 that I had before my Echo (which I bought in 2010), meaning the NX was 18 years old at the time, I was able to get control arms bolts, header bolts (at the motor and collector), and some others out reasonably well. No snapping, just breaker barring it out. The car had around 180k at the time and was winter driven by the previous owner.
Old 12-17-2013, 10:17 AM   #330
I have seen far more bolt issues as of late as well, but not just with the Yaris. I was helping a buddy of mine change his rear shocks on his relatively new Jeep and we sheared two bolts in the process. I swear that it has nothing to do with the manufacturers cheaping out on bolts, but rather on these new road salts that are being used.
Old 12-17-2013, 10:31 AM   #331
Lars
Yaris beginner
Drives: Yaris XP9F
After spending many hours under there I also now understand where the seam sealant needs to be applied to reduce the water entry and will post a DIY on that as well.
Please do... you guys are scaring me sh*tless...
I have no idea what they put on the roads here in Germany but I sure hope it's not as aggressive as what they put on yours!!
Lars is offline   Reply With Quote
Old 12-17-2013, 12:31 PM   #332
Hershey
Never had this issue with cars of the past . Would go 250,000+ miles and no bolts for suspension would fail . Struts and other related parts , yes , that's expected . Poor design of the control arm . Who supplies those to Toyota ? Subarus and other manufacturers have the same problem .
Old 01-02-2014, 12:26 AM   #333
Viperoni
Possible... I don't have it anymore, but just before I got my Echo in 2010, my 1992 Nissan NX2000 that was winter driven in Canada, didn't have any issues removing bolts.
One bolt that was memorable was the bolt that bolted the two rear lateral links (control arms) onto the spindle. I needed to use a 2 foot breaker bar and a 4 foot pipe on an impact socket and *REALLY* needed to put my weight into it.. and I'm over 200lbs. There was at least 500ft lbs of torque going into that 1/2" bolt and it survived fine.
Referencing this thread in particular, even though these front LCA bolts aren't even getting much shear load, mainly tension they're still snapping... which really makes me think it's a metal quality issue.
And my thermostat housing stud snapping issue I just had is another example...
Old 01-10-2014, 01:06 AM   #334
andulong
andulong's Avatar
Drives: 2008 Hatch Red
Finally got around to replacing my bolts today. Old ones came right out (with a long cheater bar) and still looked very good. Appeared to have only minor surface rust. I am in Southern CA and am sure that has a lot to do with the condition of the bolts. I will most likely not need to worry about this again. If I didn't have the new bolts ready to go, I would have most likely re installed the old ones. Thanks for everyone's input on this issue.
andulong is offline   Reply With Quote
Old 02-10-2014, 06:37 PM   #335
NEexpat
Drives: 2009, auto, 4dr LB
Back to this again,
Let's say, hypothetically, that there was a Yaris owner out there who was relatively certain that his/her lower control arm bolts were corroding. Based mostly on the four season climate this person lived in complete with salted winter roads.
And that this person is not at all happy with the the "reactive" attitude Toyota and subsequently their dealers are taking with this issue. Not replacing the bolts forthwith rather waiting till the customer complains of a "thunk" noise when going over a bump.
Lets say for instance that this Yaris owner wanted to be a little more "proactive" and he or she wanted to see if they could remove these bolts themselves, and if successful replace them with new bolts. Is there anything these bolts should be "dressed" with? As well as any additional sealing around the bolt hole above on the inside of the control arm.
Asking for a friend.
Cheers
NEexpat is offline   Reply With Quote
Old 02-10-2014, 08:06 PM   #336
Originally Posted by NEexpat View Post
Back to this again,
Cheers
The good thing is that if they snap while "your friend" is trying to remove them "your friend" can simply (and carefully) drive to the nearest dealership and let them perform the warranty extension service.
If "your friend" gets them out successfully "your friend" will want to seal the seams per the TSB (see the images below). I also recommend coating the bolts with something (either a heavy grease or anti-seize compound).
You can pick up caulk gun tubes of seam sealant at most auto parts stores.
Here is where the TSB shows to seal the seams
And, here is a picture of the chassis. The red lines show the three seams to seal on each side. With the subframe in place it is very difficult to see these areas, so this picture is of a stripped chassis.
Old 02-10-2014, 08:59 PM   #337
NEexpat
Thanks Scott,
I be sure to ummm pass this information along.
Old 03-31-2014, 08:39 PM   #338
Hershey
CT, if one or both of the bushings around the horizontal bolt (s) are bad, could it be a safety concern and still be the source of the crunch/creak with all the new parts ? Parts listed here, http://www.yarisworld.com/forums/showthread.php?t=50701 Maybe we should change our user name to Captain Crunch. .
Old 03-31-2014, 09:18 PM   #339
The horizontal ones have a simple steel tube bushing around the bolt. That tube is then surrounded with the compliant material (rubber, urethane, or whatever it is). I can't imagine them being bad on a new arm.
Old 03-31-2014, 09:36 PM   #340
Hershey
No new arm(s) were installed . Still the original with 72,000+ miles . Could the surrounding material inside the steel bushing deteriorate from salt , road conditions ( pot holes , etc. ) and other reasons ?
Old 03-31-2014, 09:54 PM   #341
They could potentially, but on the one where I had disintegrated vertical bolts, the horizontal ones were fine. When they dropped your subframe they would have had to remove the control arms to do so, so if they were in bad shape they should have noticed.
Old 03-31-2014, 09:57 PM   #342
Hershey
Or maybe not . Never was mentioned .
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
