Old 02-13-2013, 03:21 PM   #325
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
It's here!
I should have time to install it and my 1zz throttle body on Friday.
Also, a shot of the inside of the plenum. Those are some nice ramps leading into each runner!
By the way, what's all of this hardware that came with the manifold for? I imagine it's pretty easy to figure out once I have everything apart but I figured I'd ask.
4/20 NEVER FORGET is offline   Reply With Quote
Old 02-13-2013, 03:34 PM   #326
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
NPT plugs are for the threaded holes in the bottom of the manifold
10" PCV hose is to replace the short factory hose from the head to the manifold (this will be easy to identify when installing, it routes to the middle spout on the manifold)
The two outer spouts will re-use the factory hoses.
The two bolts, spacers and washers are used to space the radiator hose bracket away from the first intake runner. Let us know if any of this is unclear.
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 02-13-2013, 10:43 PM   #327
mr_miles
Drives: 2013 Yaris
We have some of the same days off - We should meet up and I'll help you install it! (PM me if that's something you want to do) :)
Old 02-14-2013, 06:39 AM   #328
4/20 NEVER FORGET
Mr Miles: I'll be working on it most of the day Friday at a friend's place, I'll PM you my number and if you're interested in coming out and taking a look or helping out, it shouldn't be an issue.
I have a question about the thermal gasket, do you install it directly against the head or does there need to be a o-ring gasket between the head and the thermal gasket? From the reading online it looks like I shouldn't need one but I thought I'd ask first.
Old 02-14-2013, 11:07 AM   #329
^ No, the O-ring goes in the manifold groove (or O-rings on the new mani), the head surface is flat I believe.
Old 02-14-2013, 01:06 PM   #330
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by 4/20 NEVER FORGET View Post
It's here!
Those really smooth velocity stacks are beautiful work.
Those grinding marks inside the runner throats are necessary. It's a real challenge welding thin aluminium tubing onto thick aluminium parts without getting at least some burn through. I had exactly the same issue. The ports clean up nice and easy with a grinder and there's plenty of material there so weld strength is not compromised.
There's three approaches, one is a smooth flush recesses like yours, another is smooth raised ramps...
and a third is where the stack protrudes into the plenum...
Old 02-14-2013, 01:11 PM   #331
^ Thanks, that just about covers it. Some roughness on the intake side is acceptable, it's smoothness on the exhaust side that is important.
Old 02-14-2013, 04:53 PM   #332
4/20 NEVER FORGET
Ok cool. I figured I'd still need the Orings on the manifold, I was just wondering about between the thermal gasket and the head. It looks like people are just installing them flat against the head. Thanks!
Old 02-14-2013, 05:34 PM   #333
jetblast
Drives: Gen 1 XB
Wow! That unit is sooooo much nicer than the Weapon R manifold. Quality pieces are well worth the wait.
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 02-14-2013, 06:29 PM   #334
tooter
play every day
tooter's Avatar
Yes. That slight roughness is negligible and purely cosmetic. Mine needed grinding exactly the same way.
Old 02-14-2013, 07:13 PM   #335
skeck
keckbot
skeck's Avatar
Drives: 2007 Blazin' Blue Liftback
Intake Mani Installed!
Got mine installed and oh by the way...FS stock intake manifold for Yaris.
skeck is offline   Reply With Quote
Old 02-14-2013, 07:18 PM   #336
jetblast
Drives: Gen 1 XB
Damn sharp Skeck, both inside and out!
Old 02-14-2013, 07:21 PM   #337
skeck
keckbot
skeck's Avatar
Thanks man!
Old 02-14-2013, 07:46 PM   #338
Jeff@MicroImage
"Know it all"
Looks great! Pretty sure you're the second automatic to run one and at least one other is running the Injen CAI, looking forward to your feedback after some more driving :)
Old 02-14-2013, 07:48 PM   #339
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I can't remeber, do you change over the electronics with the 1zz Throttle body or do you just plug and go faster?
Old 02-14-2013, 07:52 PM   #340
skeck
keckbot
skeck's Avatar
I swapped the electronics myself.
Old 02-14-2013, 08:13 PM   #341
tooter
play every day
tooter's Avatar
Gooks super, sheck!
Have you driven it yet? And did you need to turn down the 1ZZ idle screw?
Old 02-14-2013, 08:32 PM   #342
skeck
keckbot
skeck's Avatar
Drove to car wash and back but no freeway yet...due to rush hour...No I didn't adjust idle screw. I actually installed the throttle body about 6 months ago or so
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
