Old 08-21-2009, 10:03 PM   #19
Yes
Old 09-19-2009, 05:56 AM   #20
kompressorgpl
Drives: yaris 1.0 vvt-i
Hello! I have an alarm to put on my Yaris (from 2002). Where i can find a diagram of the car with that?
kompressorgpl is offline   Reply With Quote
Old 09-19-2009, 08:09 AM   #21
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
use a multimeter and probe the wires, and make your own diagram, thats what I did when I installed my remote starter.
Old 10-20-2009, 12:11 PM   #22
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
hi there,
may i know where can i find this stuff?
regards,
Charles
charleschia1986 is offline   Reply With Quote
Old 10-20-2009, 01:26 PM   #23
Originally Posted by charleschia1986 View Post
hi there,
regards,
Charles
If you mean where are the wires in the picture, they are right behind the pull out pocket on the bottom left of the dash.
Old 10-20-2009, 09:39 PM   #24
charleschia1986
hi there,
so did ya mean it is located under the driver seat or passenger seat? because my driver seat is on right hand side.
regards,
Charles.
Old 10-20-2009, 10:15 PM   #25
hi there,
regards,
Charles.
In that case it's behind the passenger lower glove box.
Old 10-22-2009, 06:15 PM   #26
Sora65
Drives: Beautiful :)
Correct.
Wait so i can put for than 1 wire in that hole?
Or should i use on of those clip things to wire?
i have no idea about wiring stuff :(
but i really wanna get some lights for the foot area..
Sora65 is offline   Reply With Quote
Old 10-22-2009, 08:32 PM   #27
Use the clip things (tap splices). Just sticking the wire in along side of the existing wire does not make a reliable connection.
Old 10-23-2009, 11:39 AM   #28
Sora65
But where im getting at is right?
i could put the wire i need powered in the same hole as the blue one where theres 12v?
Old 10-23-2009, 02:53 PM   #29
Yes. That blue +12 is always on though. The pink is switched ground for the inside lights.
Old 11-12-2009, 02:04 PM   #30
yoxx
yoxx's Avatar
Drives: toyota yaris 2008 hatch
How to plug in a water temp gauge?
All I really need is the signal for the temp
wich one is it, please HELP
yoxx is offline   Reply With Quote
Old 11-12-2009, 11:46 PM   #31
There's a 2 pin connector to the engine coolant temp sensor. It has a pink and a blue wire that go to pins 96 (pink) and 97 (blue) on connector C20 of the ECM.
Old 11-13-2009, 07:17 AM   #32
yoxx
yoxx's Avatar
Where r this locate it, for some reason I can't find this box you r showing me, been looking under the hood for an hour and I can't find it
Old 11-13-2009, 07:25 AM   #33
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
and the speed sensor wire ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 11-13-2009, 08:07 AM   #34
With the hood open it is to your left (the car's right) against the firewall. It is the big silver box with the two large connectors.
Old 11-13-2009, 08:11 AM   #35
The easiest place to tap it is at the speedometer. It is the pink wire in pin 17 of connector D1, which is the larger of the two connectors.
Old 11-13-2009, 01:46 PM   #36
yoxx
yoxx's Avatar
Attachment 30002
hey ctscott
i got a little problem
the water temp that i got, only have one wire for the water temp? wich one should i use for this? the pin 96 (pink wire) or pin 97 (blue wire)
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
