View Poll Results: are you interested?
yes i'm interested in 13mm spacers 13 48.15%
yes i'm interested in 10mm spacers 14 51.85%
Voters: 27. You may not vote on this poll
Old 04-30-2009, 11:22 AM   #19
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
most likely a 7" wheel.
Personally the 10mm would probably be best for you since you're running the wider tire.
Russelt3hPirate is offline   Reply With Quote
Old 04-30-2009, 11:26 AM   #20
Tamago
Tamago's Avatar
Drives: UZJ100
agreed.
so here's how it should go:
+40mm or lower (+38 for example), purchase 10mm spacers (if your tire is 215 or wider)
+40mm or lower (+38 for example) purchase 13mm spacers if your tire is 205 or skinnier)
on a 7" wide wheel. anyone running 6.5" wheels, no matter what offset should be able to run the +13 spacers without ANY issues.
and FYI the bolts are long enough to handle two sets of 10MM if one so desired. (that'll make your rear track 40mm wider!)
Old 04-30-2009, 11:26 AM   #21
kngrsll
Apexing Egg!!
kngrsll's Avatar
very difficult to do that, as i don't know the specific drop your car has. as the suspension compresses, negative camber turns into toe-in.
i could, however, provide two stainless washers to be installed under the lower front bolt. this is how i achieved my current setup (toe out, and a little extra camber)
i have the SPC shims on it right now, and i put them on when the car was stock. the full alignment really changed the car in a good way so i dont want to lose that. but i could get another set of them, put the spacers on, get another alignment, and redo the shims. i like a tiny bit of toe-in the rear, stock it has massive toe in the rear.
or i could just leave the shims as is and add the spacers :rofl:
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-30-2009, 11:27 AM   #22
Russelt3hPirate
l33t3st Asshole
damn 20mm spacer would be pretty crazy.
Old 04-30-2009, 11:28 AM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
are they the plastic shims?
Old 04-30-2009, 11:33 AM   #24
Russelt3hPirate
l33t3st Asshole
I would suggest a realignment, you never know which setting can change once you take apart a suspension. :( (don't ask why I know...haha).
Old 04-30-2009, 01:04 PM   #25
yeah, pretty sure he got them from me
Old 04-30-2009, 01:06 PM   #26
Russelt3hPirate
l33t3st Asshole
the plastic ones scare me.
Old 04-30-2009, 01:44 PM   #27
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Definitely interested in the 13mm, although my wheels are +45 with 195 tires, sooooo should I do two 10mm or what?
I was just about to buy some wheel spacers because the sucked in look in the rear is starting to piss me off.
Old 04-30-2009, 01:49 PM   #28
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
price for shipping to hawaii? :)
Old 04-30-2009, 01:55 PM   #29
About time Tamago.
Anyone noticing how NICE Tamago is in this thread?
Old 04-30-2009, 02:01 PM   #30
kngrsll
Apexing Egg!!
kngrsll's Avatar
yeah, the red ones
yah i know i should... im probably going to do shocks soon too, so i may just do it all together. why do the plastic ones bother you?
yeah, i think i did... cant wait to get my rear bar and cable bushings!
Old 04-30-2009, 02:08 PM   #31
Russelt3hPirate
l33t3st Asshole
for your setup a +13mm would be a good idea to get the most out of it.
yeah, the red ones
They are a pain to work with and not worth the price when you can get some washers that will do the same thing with a little math. :)
Old 04-30-2009, 02:11 PM   #32
33OH
Drives: '08 Yaris
I noticed.
Must be because he's asking for money. Just kidding.
Old 04-30-2009, 02:19 PM   #33
ChinoCharles
Drives: LB
Tamago is a sweetheart. He enjoys poetry, long walks in the park and hellaflush approved wheel setups.
Old 04-30-2009, 02:21 PM   #34
and wet puppy noses
Old 04-30-2009, 03:56 PM   #35
kngrsll
Apexing Egg!!
kngrsll's Avatar
LOL math :(
Old 04-30-2009, 04:41 PM   #36
Russelt3hPirate
l33t3st Asshole
LOL math :(
it isn't too hard, maybe tamago can include a calculator :lol:
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
