Old 06-16-2009, 10:03 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Loren View Post
Not to be argumentative, but toe-out on the rear of a Yaris is NOT in spec at all. The factory spec is .11" total toe in plus or minus .12", so anything more than .01" of toe out is out of spec.
i don't drive a yaris
Old 06-16-2009, 10:20 PM   #20
Black Yaris
der Zeck
Black Yaris's Avatar
pretty sure the alignment specs were the same on my Yaris as they are on my xB
Old 06-16-2009, 10:25 PM   #21
Tamago
Tamago's Avatar
Drives: UZJ100
do you do your own alignments on a rack?
Old 06-16-2009, 10:30 PM   #22
Black Yaris
der Zeck
I did it on a Hunter machine on the Yaris.... but I just watched the last time they did on the toaster..... and I always get print outs....
Back when I worked at the tire shop for a few years I used to run the alignment machine
Old 06-16-2009, 10:31 PM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
hmm, well whatever machine i use at toyota my toe-out is within spec for the xA :)
Old 06-16-2009, 10:33 PM   #24
Black Yaris
der Zeck
I am taking my car back to get aligned tomorrow (since I hit a huge crater in the e-way, and blew a tire out)
so I will be able to tell you for sure then
Old 06-16-2009, 10:35 PM   #25
Black Yaris
der Zeck
plus I went from a 205/40R17 7in ET45 with 25mm adapters to
205/50R17 7in ET 45 with no adapters
I changed the ride height and track slightly
Old 06-16-2009, 10:36 PM   #26
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Dumb question but is it really Thaaaat important to get an alignment if I just add 4 washers to adjust the camber on the rear but don't mess witht the toe? I just got one 4 months ago and the only place around here that will touch my car charges 70 bucks for an alignment.
Old 06-16-2009, 10:38 PM   #27
Black Yaris
der Zeck
yes you NEED an alignment after changing the specs like that..... $100 says most places will not touch it though
Old 06-16-2009, 10:53 PM   #28
PHXDEMON
PHXDEMON's Avatar
Well in that case. How the fuck do I tweak the front camber a couple negative degrees while I am at it
Old 06-16-2009, 10:55 PM   #29
Tamago
Tamago's Avatar
Drives: UZJ100
well, remember that the xA and xB are not identical for alignment spec ;)
Old 06-16-2009, 11:04 PM   #30
Tamago
Tamago's Avatar
Drives: UZJ100
buy camber bolts.
Old 06-17-2009, 11:38 AM   #31
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
If the spacers are that much of a problem, take them off. No point of messing your car and tires up just to be "cool" and stuff.
marlondog is offline   Reply With Quote
Old 06-17-2009, 12:44 PM   #32
Tamago
Tamago's Avatar
Drives: UZJ100
this statement is unnecessary. we might as well all drive completely stock vehicles if we live by "your logic"
Old 06-18-2009, 12:56 AM   #33
PHXDEMON
PHXDEMON's Avatar
Originally Posted by Penguin Garage View Post
Pics of your setup?
Crappy cellphone pic.
Old 06-18-2009, 01:02 AM   #34
Tamago
Tamago's Avatar
Drives: UZJ100
have you determined where it's touching? specs on wheels and tires plz
wheel:
width
offset
diameter
tire:
width
aspect
thanks!
iirc you bought 13mm spacers?
where is it rubbing?
btw the car looks good :)
Old 06-18-2009, 03:39 AM   #35
PHXDEMON
PHXDEMON's Avatar
Wheels are 17x7.5 +42mm offset
The tires are 215/45/17
The tires did rub on the rear a little before installing the spacers. I tried my best to take a pic of where they are rubbing ( as you can see the rear quarter metal is tweaked out a little bit from trying to hammer roll the fenders. The problem is I think the tires are hitting up metal higher in the wheel well.
Old 06-18-2009, 11:46 PM   #36
PHXDEMON
PHXDEMON's Avatar
I think adding some toe out on the rear may help but I don't want to prematurely wear the tires.
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
