#19 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Not as likely to crack, but no real benefit. Again, trying to address the outgassing issue that modern brake pads don't have. They do tend to act as a cheese grater and wear your pads quicker, though.
#20 |
What?
Correct, the holes are cast into the brake rotor at the time of manufacture.
#21 | |
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
#22 | |||||
Drives: 2007 4 Door Yaris Join Date: Jan 2009
edit: oh but the bling is totally why I bought them. All the people that pass within 3 feet and catch just the right angle looking through the little hole in my steelies drool in envy of my drilled goodness. |
#23 | |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
to order the lines designed for the Vios with rear discs.
http://www.cardomain.com/ride/3875996 |
#24 |
resident senior
I have to agree with Supmet . D/S rotors do dissipate heat better . More air to more surface area = more cooling . Thats the whole theory behind vented rotors . As far as D/S rotors chewing up pads like cheese graters , false . For your rotors to be grated there would have to be a trailing edge that is raised . ( Go check your kitchen drawer ) . Carbotech pads will decrease the life of your rotors simply b/c they are harder and will grind away more material . Carbotech pads do take longer to heat up which in turn helps the seals in your calipers from melting and also helps to keep your brake fluid from boiling as quickly .
Cracks form from a combination of circumstances . The main one being from a manufacturing defect . When you cast anything , it is virtually impossible to obtain an even thickness throughout . Combine this defect with some heat and poor braking habits and viola ...a crack will raise its ugly head . If there is one crack ( from hole to hole ) that rotor is still usable but you would be wise to monitor for more cracks . I've seen many people do this ( On track ) . If a crack extends from hole to hole to hole , then you need to trash that rotor . If a crack extends from the outer hole to the outer edge then you will get a cheese grater effect from the warpage that will follow . Speaking about on track , I have used the R-1 rotors on track ( against R-1's advice) and they work pretty darn good . The last time I went to Roebling Road . We did 100 + consecutive laps . The Yaris did come in the pits for driver changes but the car never shut off . We experienced no brake problems . Actually the Pros who drove my car said the brakes were surprisingly good . ( I'll get to my secret in a minute ) . We tried our darndest to find a flaw anywhere in the car . The only one we found was lack of power . But the R-1's did glaze up in the mountains . Which is why I bought new rotors from brake warehouse . The R-1's are still good but just wanted to try something else .My brake setup is as follows : Toyota pads , Brake Warehouse rotors , SS lines and ATE Blue fluid . Check the pics below . On the car are the BW rotors . On the ground are the R-1 rotors . Check out the differences . The R-1's have bigger holes and slightly longer slots . The R-1's also have the hole closer to the outer edge . The BW rotors have 2 rows of holes between the slots . The BW have a powder coated hub/hat . The R-1's were zinc plated in its entirety . Both have pointed end slots . The things I don't like about the R-1's are that they took longer to bed in b/c on the zinc plating and they glazed in the mountains ( after turning a pretty shade of blue ) . With a good bit of fade What I like about the BW rotors is that there are more holes , albeit smaller than the R-1's , and the holes are not so close to the outer edge . I also like the powder coating on the hub/hat area . The rust doesn't "bleed" through like they do on the R-1's . I've gotten these rotors a nice crimson color in the mountains with no adverse affects Just a tiny bit of fade . Now for my trick . Notice the R-1s . The one on the right is how everybody else installs their rotors . The holes are slanted towards the rear of the car . The one on the left are slanted towards the front of the car . My theory is that with the holes slanted forward it allows the outer edge to cool first after leaving the pad area thereby producing more consistent results after repeated use . The pros who have driven my car all say the can't believe how consistent my brakes are especially with stock pads . Then I point out my rotor orientation and they go "Hmm interesting" . 6 hours have elapsed since I started this reply to the time I posted . ( GF's Mini broke and I had to go and fix it , Tranny and flat tire ) So I probably missed a few replies .
#25 |
What?
I'm not going to argue with you guys, but I'll tell you that I take most of my information from reliable sources. I consider a brake system engineer who also has experience building race cars and racing is pretty high on my list of reliable sources for brake info.
Here's what James Walker (I'm pretty sure he knows more about brakes than any of the rest of us do) has to say about brake rotors: http://www.teamscr.com/motorsports/t...or-rotors.html |
#26 |
HTM, that is how I have my front rotors oriented as well.
#27 |
#28 |
Hmmmm
, me likey a lot
#29 |
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
Nice. :)
Tantum religio potuit suadere malorum. |
#30 |
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
Did you reuse your stock shims on your break pads?
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
#31 |
Yes I did, perfect fitment on the Carbotech.
#32 |
Rides canyon walls
Ok cool, thanks for the info. I just bought some carbotechs from garm as well, but I'm too sick to work on my car right now :'(
#33 |
resident senior
Hey Loren , no harm , no foul . I love a civilized discussion . On that note , let me point out some of the fallacies in Mr. Walker's thinking .
Mr Walker states that holes were developed to eliminate gassing . I can buy that . Mr Walker fails to mention that holes evacuate dust quicker ( which is also the reason for the slot on most brake pads ,which he fails to mention ) , which in turn increases coefficient of friction . Mr Walker goes on to mention that if weight is removed from the rotor that heat can increase a "little" , but he fails to mention how long that "little" bit of heat is sustained . He goes on to mention the "cheese grater" effect . This is another half truth . When a crack develops there is only a 50% chance that a grater effect will occur . If the leading edge of the crack is raised , then it effectively becomes a slot . As I stated previously if you have a large crack or a crack to the outer edge , I highly recommend a rotor replacement because your structural integrity is compromised . Mr Walker also didn't take into account that Nascar and F1 don't allow holes . Not to mention that Nascar and F1 use carbon rotors . He also doesn't mention the inconsistencies of the casting process as opposed to the machining process that produce exact tolerances , which Nascar and F1 use . I laughed my ass off when I read the "Too Cool" segment . Everybody knows that when you freeze something the molecules will draw closer together and then when you heat it up it will revert back to its previous state . This is easily proven with water . Think ice cubes . Sometimes water expands because air gets trapped . I feel certain that the people at the testing facility laughed all the way to the bank . In my opinion Mr Walker needs to refine his research methods and offer more conclusive objective data . But on the other hand , I don't offer any data either . Just simple logic and my own personal experiences . Which by the way are not for profit . I could go on and on but my GF wants to apply some friction principles of our own .
#34 | |||
Oh and his ONLY argument(not just stating random facts he holds as truths) was that nascar and f1 cars don't use drilled brakes. Because, you know, the average car driver has a couple grand to spend on carbon fiber brakes, and replace them everytime they drive the car. Also, an engineer should realize the orders of magnitude of difference in the forces braking from 220 and braking from 120. But lets compare apples to oranges.(and do it multiple times in a one page article). I passed a dinan bmw with slotted rotors and a carrera s with drilled going in to the store today. The ferrari 430 challenge came with drilled rotors one year. I'm gonna take the word of ferrari, dinan, and porsche over this random guy. ...(runs off to buy a fire suit and helmet, because if NASCAR does it, well by golly I'm gonna do it) |
#35 |
What?
What do you guys not understand about "I'm not going to argue with you?"
My most compelling reason for "hating" cross-drilled rotors is simply having seen with my own two eyes far too many of them CRACKED at track events. Given the choice between driving on a race track with a rotor that's likely to crack and one that isn't, I'm going to choose the one that isn't. I'm funny that way. Y'all can continue arguing amongst yourselves. |
#36 | |
For the race track, you are probably right. But for street or auto-x use, I really do think they dump heat faster(leading to better brake performance and longer lasting pads and rotors), clear dust, are slightly lighter, and yes - they look better. Plus you can get a pair for $110 from garm, or one stock rotor for $96 from the dealer. I think they are the best bang for the buck rotors for performance and longevity. As far as cracking, I'll never put as much heat in to them as fast as I did when I bed my pads again. If they took that they should be good.I would be interested in some hard testing of the same rotor, same car, drilled and not, infrared thermometer mounted in the wheel well. Surely with some companies making claims of 200 degrees in difference there would be some, but I'm finding it extremely hard to find. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| OEM Yaris brake pad kit PICS | auxmike | DIY / Maintenance / Service | 17 | 11-24-2009 11:42 AM |
| Will XA XB's brake line fit our Yaris?? | AlainMikli | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-04-2009 01:22 AM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
