Old 08-27-2009, 11:25 PM   #19
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Maybe try putting back your stock wheels. If it makes the same sound, then it's the car.
If it doesn't make the same sound, then it's your new wheels.
You said it's only around 30 mph when you hear the noise right?
It could be just the sound when spinning at that speed. Bad example but like when you start spinning a wheel slowly and as you increase its speed, the wind resistance at the point generates a sound at that frequency, but spin it faster or slower and you don't hear it any more because you can hear the sound only at that frequency.
Sorry, I really don't know otherwise.
Old 08-27-2009, 11:44 PM   #20
Taiyaki
アキバ製
Taiyaki's Avatar
Im pretty sure its the wheels. When I changed my wheels the stock wheels werent making noise but after changing it, it started to make the noise.
I also noticed that I hear it at around 58-ish mph.
Old 08-27-2009, 11:44 PM   #21
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Hmm...
If you checked the wheel bearings/hubcentric rings/etc. , then i don't know what else it is. I've never heard that sound before. It sounds like soemthing is out of balance. Did you install rear shims??
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 08-27-2009, 11:46 PM   #22
anonymous user
Drives: 07yaris
My car was running like neg 4 camber for a while, and it sounded like that, except a lower pitch sound, as wind was passing under the tires.
I'd bet it is wind passing through the rim, or check your alignment to see if that is causing the noise. I'm betting it's just wind passing through. No biggie.
Old 08-27-2009, 11:49 PM   #23
Taiyaki
アキバ製
Taiyaki's Avatar
Whats that? haha
Im sure that the rings are in right, but how do I check the bearings?
Old 08-28-2009, 03:55 AM   #24
Shims are used to add negative camber in the rear, I believe.
Old 08-28-2009, 04:04 AM   #25
Taiyaki
アキバ製
Taiyaki's Avatar
Oh ok, yeah I dont have that. haha
Old 08-28-2009, 07:40 PM   #26
Taiyaki
アキバ製
Taiyaki's Avatar
Ok its not my wheels bearings or my car. I just put my steelies back on. Gave them shake but there is no play. then when I drive I dont hear the sound.
OMG so strange!! I think I will take it in and get it balanced and see if they know.
Old 08-29-2009, 03:05 AM   #27
Hope it's nothing serious.
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 11:56 AM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 08:37 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
strange noise nisyota DIY / Maintenance / Service 7 03-05-2009 08:39 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
