#1 | |
![]() Drives: Yaris 1,3 -01 Linea Luna Join Date: Feb 2010
What EWD do you have? Last edited by Falconia; 02-19-2010 at 03:51 PM. |
#2 | |
#3 | ||
Does the EWD which you have "say" that I have to disconnect just a yellow wire. Or does it say that in US 2001 Yaris DRL have to be completely disconnect. Quote:
#4 | |
For the second question of Yellow or Blue, he is talking about a 2nd Gen Yaris DRL, which is wired completely different than the first gen DRL module. |
#5 |
![]() ![]() Drives: 2010 Yaris 3-door liftback Join Date: Mar 2010
I have a 2010 liftback and the manual mentioned DRL. But when I turn on the car the headlights do NOT go on. ??? Should I complain?
#6 |
Hi again,
I have now the second Bi-xenon bulbs in my Yaris. These new bulbs has worse flickering problem compares to older ones. Passenger side bulb is flickering especially when starting engine, pretty bad I think. My hid is connected directly to the battery. I have heard about relay harness, but is that going to change anything because my hid is already connected directly to the battery. What about capacitor decoder which is used to flickering also, that stables the current, I think. How I resolve flickering problem in that situation? Relay, Capacitor?! ...and I have hi/lo kit where relay harness came with the kit |
#7 | |
The flickering is because of the ground being pulsed, so the direct connect to the battery has no effect. A large capacitor should take care of the issue. Use two 4700uF (25V or greater) capacitors. Connect the capacitor across the input power to the ballast (making sure that you match the polarity).
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 06:46 PM |
