Old 10-24-2011, 08:18 PM   #19
Connoisseur_of_fine_cars
Oh what a feeling
Connoisseur_of_fine_cars's Avatar
This probably only applies to stick shift Yaris...
I notice that when I turn the A/C on, the idle RPM goes up a little bit, and the throttle is much more responsive from idle than with the A/C off. I sometimes inadvertantly stall the engine, usually when I'm not using the A/C. All my other cars have idle at 800. Did Toyota set it at 600 for some reason? Like emission? Will my car fail emission test if I increase the idle to 800? Will CEL come on?
Connoisseur_of_fine_cars is offline   Reply With Quote
Old 10-10-2012, 03:51 PM   #20
Krazzyd
Drives: toyota vitz 06
HI I HAV A 2006 VITZ HATCHBACK I TOOK OUT THE BATTERY WHEN I PUT IT BAK IN THE CAR STARTS TRACKLING LOW AND SHUTS OFF...NEED HELP ASAP PLEASE THANKS
Krazzyd is offline   Reply With Quote
Old 05-10-2020, 02:08 PM   #21
pabli999
Drives: Yaris sedan
My Yaris if the idle gets too low the a/c stop cooling and if I put in neutral and accelerate it’s start cooling again. I’ll give a try in that screw to see if work better.
pabli999 is offline   Reply With Quote
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
what is the idle speed on stock 09 HB ezhacker1 General Yaris / Vitz Discussion 5 05-17-2009 08:49 AM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
