Old 10-15-2010, 03:45 AM   #1
Incillio1
Drives: '09 Yaris Sedan
Raising Idle speed?
I have a '09 Yaris sedan and want to adjust my idle speed. Is that impossible because of a computer the car runs off of? I just want a little more rpm at idle.
Thanks
Incillio1 is offline   Reply With Quote
Old 10-15-2010, 04:39 AM   #2
typicaljawaiian808
Same here
Pioneer
Ascendant Audio
Sundown Audio
DC Power Engineering
Knukoncepts
Fosgate
Stinger
typicaljawaiian808 is offline   Reply With Quote
Old 10-15-2010, 09:25 AM   #3
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
You can adjust the idle screw on the throttle body . Its on the top and its uses a very small allen wrench to adjust it . Im pretty sure you want turn in clockwise to raise the idle rpm . Also you have to adjust with the engine off .
Old 10-15-2010, 03:24 PM   #4
detroiter
detroiter's Avatar
I looked myself for this screw and didn't find it. I did see a screw that was encased in glue or epoxy, that you couldn't get to though.
Old 10-15-2010, 03:28 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
That's it, you need to get the epoxy off. Just make sure to adjust your idle when the car is OFF.
Old 10-15-2010, 06:56 PM   #6
detroiter
detroiter's Avatar
Can i ask what reason their is to adjust the idle speed or what would cause it to lower? Since it's epoxied in, I just wonder how it could happen and why you would want to change it.
Old 10-15-2010, 07:06 PM   #7
typicaljawaiian808
For me, im running a very large sound system and I need to give my aftermarket alternator 1 - 200 more rpm at idle
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 10-15-2010, 07:07 PM   #8
typicaljawaiian808
oh yeah thanks for helping us find that adjusting screw
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 10-15-2010, 07:11 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Can somebody please post a picture of where ti is located? I can't for the life of me find it.
Old 10-15-2010, 08:15 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
It's located here, although this member replaced his idle screw because he stripped his out I believe. The stock screw is recessed, behind some yellowed epoxy. It's in the same area though, hope this helps.
Old 10-15-2010, 08:19 PM   #11
typicaljawaiian808
Clockwise or Counter-clockwise to raise the RPM? Thanks again for the help!
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 10-15-2010, 08:31 PM   #12
Astroman
Modded Moderator
Astroman's Avatar
Oh that pic is at the wrong angle, just tip your monitor/laptop on the right side and you'll see exactly where it is
Old 10-15-2010, 09:28 PM   #13
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
yeah based on this picture I can tell, thanks! I'll give it a shot tomorrow maybe
Old 10-16-2010, 05:23 AM   #14
typicaljawaiian808
I found everything and successfully upped my rpm to ~800 + or - maybe. The sound sysytem seems to be liking it 1,000,000 times better.
I took pics of the whole thing so i'll get those up soon. Thanks to everybody that new what they were talking about!
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 10-19-2011, 03:04 PM   #15
umairamin
Drives: yaris 2008
idle problem
My car have also problem with idle and idle is going very slow and car is giving vibration if i change this setting which is covered with epoxy ,will it damage the
throttle body and why company is secure with epoxy?
Thanks?????????????????????
QUOTE=Incillio1;523229]I have a '09 Yaris sedan and want to adjust my idle speed. Is that impossible because of a computer the car runs off of? I just want a little more rpm at idle.
Thanks[/QUOTE]
umairamin is offline   Reply With Quote
Old 10-19-2011, 03:05 PM   #16
umairamin
Drives: yaris 2008
Old 10-19-2011, 04:30 PM   #17
RedRide
RedRide's Avatar
It's "expoxied" simply so it wont move due to vibrations and it usually does not go out of adjustment.
However, since it is a mechanical adjustment, it can be prone to some wear that can throw it out of spec just like a standard cable actuated throttle.
So, keep in mind that even though it was set at the factory, it stiil may have to to be readjusted depending on conditions.
Old 10-19-2011, 04:31 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
turn on your A/C
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
what is the idle speed on stock 09 HB ezhacker1 General Yaris / Vitz Discussion 5 05-17-2009 08:49 AM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
