Old 01-23-2011, 01:01 AM   #19
SAV912
Pirate Yaaaaris
SAV912's Avatar
No springs are ever in desperate need of being cut. If you already have lowering springs, then live with it at that level. If you want to go lower, your options are coilovers, airbags, or cement blocks. Or fat bitches.
I honestly can't believe that one person says it and all a sudden it's a legit, okay thing to do.
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 01-23-2011, 01:27 AM   #20
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
To each their own. Easier n cheaper to cut then to spend ovr grand to lowr a car. Especially a yaris. I wud considr coilovrs if i had a sports car/sedan with alot more powr than 105hp. All for show no go!!!
"who the cap fit let them wear it"
20104dr is offline   Reply With Quote
Old 01-23-2011, 02:15 AM   #21
Viperoni
Drives: 2005 Toyota Echo
Cutting a coilover spring is a legit thing to do.
Cutting ANY spring WILL increase its spring rate.
Cutting the pigtail off a stock spring is usually not the best thing to do.
Heating any spring is just plain dumb.
Old 01-24-2011, 11:56 AM   #22
Yaristeve
Drives: 3-door hatch
In general, there is NOTHING wrong with cutting springs. Spring rates are a function of wire diameter, coil diameter, and number of coils. Cutting the coil WILL stiffen the spring inversely propotionally to the number of coils cut. As some old-timers (and I am one) have said, back in the day, cutting coils was often the only way to lower cars. I have cut my share of springs and never had a problem. You can't just go cutting willy-nilly; it takes careful consideration.
HOWEVER, having said that, Yaris springs, from the pictures I've seen, cannot be cut because the coil diameters are not uniform throughout the length of the spring. IIRC, the coils get smaller at the ends. If you cut these end coils, the springs will not sit in the seats correctly. and besides, as yet others have said, loering springs are available so you might as well use those...
Old 01-24-2011, 11:54 PM   #23
johnny_vitz
The issue is when people cut springs with a torch. You should never heat a spring to make it sag, or cut with a torch. A friend heated his back in highschool and two weeks later one blew apart and took out his tire.
20104dr - You have a brand new car and you don't think it's worth $200 to buy a set of nice springs for it?
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 01-27-2011, 12:48 AM   #24
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
i have dfs but not low enuf for me. i was talkin bout buying coilovers. i wud nevr torch them.
Old 01-27-2011, 02:59 AM   #25
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
You can go low on the cheap; just strategically place sandbags all over your car until you've reached your desirable ride height. Voila.
Sponsored by: Micro Image
http://microimageonline.com
Old 01-27-2011, 09:26 AM   #26
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
For sure don't use a torch. I used a grinder and then painted the exposed end
xxae07xx is offline   Reply With Quote
Old 01-27-2011, 09:52 AM   #27
larryn2o
larryn2o's Avatar
Drives: 08 yaris
i found some circle track springs at the speed shop, cut them to get an inch of drop AND they are stiffer. so the car doesn't bottom out when i pull a trailer. may not change the front as the car sits level now.
thanks for the input
Larry
larryn2o is offline   Reply With Quote
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
HAS ANYBODY CUT THEIR STOCK SPRINGS Moses General Yaris / Vitz Discussion 4 01-19-2010 10:55 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
What about cut the springs? Yaris_PR Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 04-07-2009 04:41 PM
