Old 07-19-2011, 09:59 PM   #19
That's what I figured. Do you know what resistor to use?
A value between 270 to 350 ohms is perfect. That will fool the ECM into thinking that the water temp is between 172 and 186 F.
Old 07-21-2011, 06:07 PM   #20
NickNickNick
Drives: 06 Silver Yaris 3-door Manual
Engine is out. Upon looking at other parts of the car, the clutch is also going to need to be replaced, which I am doing while the engine is done. I beginning to think more and more than there was something seriously wrong with my car that no one caught about 7000km ago when I had it in.
I have started a case file at Toyota to see what they have to say.
On the other hand, I am extremely pleased with the service I have gotten from this particular Toyota dealership. They have really done an excellent job of explaining to me what they are doing and why it needs to be done. I have very little other than basic knowledge about cars, and the service provided at Moose Jaw Toyota has been excellent.
NickNickNick is offline   Reply With Quote
Old 07-21-2011, 06:41 PM   #21
Jason@SportsCar
The drive belt is a wear item, and if you were still on the original you were likely well past its useful life.
Old 07-21-2011, 07:12 PM   #22
NickNickNick
I have two reports. One from June 21, 2010 where the drive belt was loosened and lubricated.
The second from May 5, 2011 where the drive belt was checked and reported as being in excellent shape.
The issue isn't really the drive belt anyway - it's the fact that I paid good money for a brand new car that I thought would last at least 10 years without any engine trouble.
We bought a 1998 used Cavalier shortly after the Yaris for my wife, and it has 200,000km on it with no issues at all.
Had I know I was going to have to pay $3000 to have the engine and clutch replaced on this vehicle, I would have bought a used car of a whatever brand I could get the best deal on. I bought a new Toyota because I believed in the reliability claims they make all of the time. I find it VERY difficult to believe that when I had all the parts of my car fully checked 7000km ago, they would miss a belt problem, engine problem, and a problem with the clutch (which is almost completely snapped off). Sounds defective to me.
Old 07-21-2011, 08:09 PM   #23
bankrobber
Drives: 2007 Yaris Hatchback
How many miles you have?
I have not had a single problem with my 07 Yaris in 115,000 miles only had a light bulb replaced. BTW 3,000 is way too much for an engine and clutch it should not be more than 2,000 tops
Old 07-21-2011, 08:14 PM   #24
Jason@SportsCar
Lubricated the belt. OK. The service you get is only as good as the place you take it, and I would be suspect of any place that said they lubed a belt.
A number of things could cause a belt to fail or come off... A piece of debris from the road kicked up, if the water pump was going and had excess end play. I lost one when our aluminum crank pulley (not stock) split in two. Bad stuff happens to cars.
I would love to see a pic of an almost snapped off clutch. How does that happen, and what is it almost snapped off of? I don't know of any service inspection that checks a clutch, hard to see it without pulling the trans.
Seems like there is more to this.
I have a 2001 Expedition with 199450 miles on it, and a 2007 with 40k, guess which one has spent more time at the dealer. Its the newer one. Sometimes your are lucky with a car, others times, not so much.
Old 07-21-2011, 09:12 PM   #25
bankrobber
[QUOTE=Jason@SportsCar;595912]Lubricated the belt. OK. The service you get is only as good as the place you take it, and I would be suspect of any place that said they lubed a belt.
I was wondering same thing. I sprayed some penetrating grease stuff on bottom bolt and I think it got on my new belt and caused it to slip a tiny bit at start up with A/C turned on. I remember people using belt ease to quiet a belt. I replaced my belt when it was getting too many cracks. A decent mechanic could replace belt in same time to "lubricate" it. New cars should come with a shut off feature when oil or water gets too hot. My Mack truck will shut off engine Before it gets hot enough to cause damage.
Old 07-25-2011, 01:29 PM   #26
NickNickNick
The place that lubed the belt was Toyota. The place that did the full check was Toyota. I have had all major service intervals done at the Dealership.
Old 07-25-2011, 01:30 PM   #27
NickNickNick
127,000KM.
Old 07-25-2011, 02:11 PM   #28
Jason@SportsCar
There are bad dealers (mostly bad employes) out there... We took our 4Runner in for a cat replacement. The dealer told us they suspected we had run diesel in the truck and that caused the failure. First, we know which fuel to put in our cars. Second, in the US the diesel nozzle is bigger than a standard nozzle, and won't physically fit in the 4Runner. Dumb @ss. This same dealer also left the oil filter loose on our Tundra. It leaked oil all the way back to our office, and a big puddle in the parking lot. We don't go there anymore.
I suspect you are dealing with a Dumb @ss, or you are leaving information out. How about pics of that almost completely snapped off clutch? Were those the dealers words, or yours? If that was the dealers description of your clutch problem I would say you need to find a new shop, one that does not have 17yr old kids working as service writers.
Old 07-27-2011, 02:07 AM   #29
NickNickNick
The dealership that did my repairs has been excellent. I don't have any pics of the clutch, though I did see it, and it was completely worn in places on the lever. "Snapped off" were my words.
The dealership that has serviced my car in the past, however, is definitely a problem. I have a lot of conflicting reports between these two places.
Old 07-27-2011, 02:09 AM   #30
NickNickNick
Also, the plates/discs/whatever you call them on the clutch itself were obviously damaged. Hard to tell if it was wear.
Old 07-27-2011, 02:11 AM   #31
NickNickNick
And, the plastic dipstick that was in the old engine was really warped/melted from heat. I don't understand how an engine could get so hot without so much as an engine light coming on at some point. I must've blown the temperature guage long before then.
Old 07-30-2011, 11:25 PM   #32
NickNickNick
Update time.
New engine installed. New clutch installed. I have put about 1000km on it since I got the car back. Seems to work just fine so far. My gas mileage is also up on the last tank and half fill, from about 6.6L/100km to 6.1L/100km.
I have not received a call back regarding my case with Toyota as of yet.
One thing I did notice the other day - after driving about an hour at 90-100km/hr, I stopped the car at a rail crossing on a local grid road. I was planning on grabbing something out of the hatch. As I brought the car to a complete stop, the car made, what seemed to be, a loud vibrating sound, and felt like it shook a bit (almost like what happens when you idle the car in too high a gear at too low a speed). I was in the process of shutting the car off, which I did. I gave the engine a quick look before re-starting the car, and I have driven about 300km since, both in city and highway, and this issue has not occurred again. I don't believe I had the car in gear partially when I stopped. Anyone know of this happening?
I've also noticed that sometimes when I start the new engine up, it idles at about 1500rpm, then slowly, over about 1 minute, the rpm falls to about 900. Anyone know what's up with that?
Old 07-31-2011, 02:19 AM   #33
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
This had just happened to me, my belt came off because the water pump gave out on me, and the pully was lose (I'm able to wiggle it back and forth with just one finger). Belt came off and right away my check engine, battery light came on then the overheating symbol came on when I got to a red light ( I didn't know the belt came off at this time) and i shut the car off till it turned green, driving a couple feet the engine cold light came on just like you said, thankfully i was around the corner to my gf's house I got there and opened the hood heard the boiling liquid and noticed right away my belt was gone.
But you have far more damage than me, i just have to replace my WP and belt, good luck to you.
Also I think thats normal it starts up cold at 1500rpm and goes down to around 600rpm i think its suppose to be, thats how my yaris starts up cold everytime. My engine actually went low as 400 rpm which was odd because the whole engine started to shake, hasn't happened in a long time though.
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 07-31-2011, 12:28 PM   #34
fj40dave
fj40dave's Avatar
Drives: '08 HB
Take it back and have the dealership run the codes....see if there's a sensor that's not reading right/not working correctly. Sounds like something with the speed sensor or idle sensor.
fj40dave is offline   Reply With Quote
Shorter Serpentine Belt? The Architect Performance Modifications 6 04-20-2021 10:42 AM
anyone has a DIY change serpentine belt on yaris sedan rufnnek DIY / Maintenance / Service 0 06-16-2011 06:15 AM
Serpentine belt broken with oil on it HerYarisNotMine DIY / Maintenance / Service 10 05-31-2011 02:51 PM
serpentine belt for 2007 yaris hatchback nikki9 DIY / Maintenance / Service 4 04-09-2011 09:22 AM
serpentine belt 1.3 engine `psycho DIY / Maintenance / Service 2 04-08-2011 10:40 PM
