Old 08-13-2012, 08:15 PM   #19
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I had to go through my firewall with my eBay fogs gq. I remember you saying you weren't comfortable with rolling/pulling fenders so this may not be something you want to undertake. It took me >5 hours but I'm not the best at wiring/electrical either.
Old 08-13-2012, 08:19 PM   #20
Whereas I installed a set of Micro Image ones on Crashy2 last night in less than an hour. That involves a couple of tricks though, that I've leaned over time, like only disconnecting the top of the bumper, rather than pulling the bumper entirely off.
Old 08-13-2012, 08:37 PM   #21
1.5
Form>Function
1.5's Avatar
O that's a good one Scott I will try that next time.
Old 08-13-2012, 09:50 PM   #22
I'm a little confused, here is a "stock" photo of a 2010 sedan:
Here is my 2007 sedan:
The 2010's bezel looks completely different from mine.
Old 08-13-2012, 09:59 PM   #23
That's not a plain 2010, it's a 2010 S, which would come with fogs from the factory. The non-S 2010's had the same fog light trim as the pre-2010s.
Old 08-13-2012, 10:50 PM   #24
lol, wow, an S model that's actually quite different than the other trim levels.
So all non-S sedans are basically the same with the exception of the front top grill?
Old 08-13-2012, 10:52 PM   #25
1.5
Form>Function
1.5's Avatar
That and wheels/hubcaps are the only differences I've noticed.
Old 08-13-2012, 11:29 PM   #26
Does anyone on here have an 'S' sedan? I've never seen one in person.
Old 08-13-2012, 11:32 PM   #27
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
Yes. But, the difference between these $40 ones and the MicroImage $100 kit is that the MicroImage one includes the wiring pieces developed by Ray (1NZYaris1), which allow you to install them using the existing factory wiring through the firewall.
If you are installing them yourself this saves a large amount of work, as the $40 kit will require you to pull the battery and wiper tray to get at the firewall grommet to run the harness through the firewall.
To modify the $40 kit to use the factory wiring you would need to purchase the two pins for the under-hood fuse panel connector ($12+ each) and the fog light relay for the under-dash fuse panel ($20).
yeah ur right ill just fork out the 100$ to M.I and support or guys
g.q.vios is offline   Reply With Quote
Old 08-13-2012, 11:33 PM   #28
Only one I knew of was Adejong (sp?). He had Work CR-Kai wheels, Bride seats, and some other goodies. He since parted out his car and...well, not sure. lol
Old 08-13-2012, 11:35 PM   #29
His was an 09 S sedan
http://www.yarisworld.com/forums/showthread.php?t=28385
Old 08-13-2012, 11:36 PM   #30
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
I've never seen one ethier!!!!
Old 08-13-2012, 11:40 PM   #31
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
Nah the wiring part i got im good with the electrical I have my amp cable runing through the firewall... My day time running lights i have them hooked up to the parking lights so when ever im driving i just click once for day use and twice for night use... I love messing with wires its fun.. I wired my whole car audio system myself too... It's my first love...
Old 08-14-2012, 02:03 AM   #32
808Yaris07
Drives: 2007 4dr Yaris
Hey guys...so for my 2007..best bet is to get the 100.00 kit? I don't have fogs in mine right now..
808Yaris07 is offline   Reply With Quote
Old 11-08-2013, 06:27 PM   #33
sickpuppy1
Drives: 2010 Yaris Sedan
Now I bought a set off ebay, but now instructions on wiring hook up. Has the wiring with plugs on ends but no idea where your supposed to hook it all to. Is the spot for sedan switch supposed to be on center console right behind the traction control button? Looks like a switch knock out is there. I'm sure I can fumble through it. looking for more confirmed Ideas of where to go with it. Where is the factory wiring hook up at firewall?
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 12:29 PM
Installed my ebay sedan fog lights today and trd grill badge.... YarisSedan Cosmetic Modifications (Exterior/Interior) 9 11-20-2009 09:54 PM
fog lights, cost of installing them at the dealership? kuyachris84 Cosmetic Modifications (Exterior/Interior) 33 05-24-2009 07:05 PM
