Old 07-25-2012, 02:33 PM   #1
Cutie Pie #2
Drives: 2014 Honda CR-V LX
New fog lights installed
Got a great deal on some fog lights that come with everything needed to make them work on ebay I got these for $38 with free shipping, just got them professionally installed for $100. I was going to install myself but just didn't want to deal with it. http://www.ebay.com/itm/JDM-06-09-TO...#ht_4557wt_975
Sorry for the large photo!
Cutie Pie #2 is offline   Reply With Quote
Old 08-03-2012, 06:08 PM   #2
LikeCaseyJones
LikeCaseyJones's Avatar
Drives: 2009 Toyota Yaris Sedan
Nice! How are they at night? I need to get some.
LikeCaseyJones is offline   Reply With Quote
Old 08-03-2012, 07:51 PM   #3
Cutie Pie #2
They are bright enough for what they are! I'm overall pleased with them.
Old 08-03-2012, 08:12 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
EBay fogs ftw that's where mine came from.
Old 08-04-2012, 07:54 AM   #5
willygoodness
Drives: 09 yaris hb
if you don't like how bright they are, you could always put in some HIDs. i've had 55w ones in my ebay fogs for nearly 2 yrs no problems at all. lights up all over the place (Y)
willygoodness is offline   Reply With Quote
Old 08-04-2012, 10:03 AM   #6
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Looks good... any time I see a Yaris without them I think that something is missing!
Old 08-04-2012, 10:38 AM   #7
1.5
Form>Function
1.5's Avatar
I am planning on this too
Old 08-12-2012, 11:55 PM   #8
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
Will these work on a 2010 sedan????
http://www.ebay.com/itm/06-08-TOYOTA...05%26rk%3D4%26
g.q.vios is offline   Reply With Quote
Old 08-13-2012, 03:06 AM   #9
Aren't the foglights for the 2010 sedans shaped slightly different from the 07-08?
Old 08-13-2012, 06:46 AM   #10
1.5
Form>Function
1.5's Avatar
I heard the same ^
Old 08-13-2012, 10:27 AM   #11
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
damit thanks guys then going to have to dish out 100$$$
Old 08-13-2012, 10:43 AM   #12
The fog lights themselves are identical. It is the plastic trim pieces that changed.
Old 08-13-2012, 12:22 PM   #13
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
thanks scott...
Old 08-13-2012, 01:02 PM   #14
In that case, g.q. is better off buying the foglights by themselves vs to buying a kit that includes the bezel already, right? Probably save some money that way.
Old 08-13-2012, 02:50 PM   #15
PatrickJohnson
Drives: 2008 Yaris LB
^---That's certainly one way to go. You can get the bezels separately on ebay all day long and for pretty cheap too.
PatrickJohnson is offline   Reply With Quote
Old 08-13-2012, 03:09 PM   #16
Actually, looking again at the EPC, 2006-2011 Sedans are all the same for both the lights and the trim (and, that's how they are shown as well on MicroImage's listing):
http://shop.microimageonline.com/Fog...-foglights.htm
Old 08-13-2012, 06:06 PM   #17
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
are you sure ct dont want to spend 100 when i can spend 40$$
Old 08-13-2012, 06:54 PM   #18
Yes. But, the difference between these $40 ones and the MicroImage $100 kit is that the MicroImage one includes the wiring pieces developed by Ray (1NZYaris1), which allow you to install them using the existing factory wiring through the firewall.
If you are installing them yourself this saves a large amount of work, as the $40 kit will require you to pull the battery and wiper tray to get at the firewall grommet to run the harness through the firewall.
To modify the $40 kit to use the factory wiring you would need to purchase the two pins for the under-hood fuse panel connector ($12+ each) and the fog light relay for the under-dash fuse panel ($20).
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 12:29 PM
Installed my ebay sedan fog lights today and trd grill badge.... YarisSedan Cosmetic Modifications (Exterior/Interior) 9 11-20-2009 09:54 PM
fog lights, cost of installing them at the dealership? kuyachris84 Cosmetic Modifications (Exterior/Interior) 33 05-24-2009 07:05 PM
