Old 02-24-2013, 08:06 PM   #19
racerb
Is there anyone making a replacement bushing for the trailing beam on these cars? I ran a Nissan several years ago with a simular rear set-up and the Nismo replacement bushings for that car made a world of difference.
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-24-2013, 08:20 PM   #20
NJ Drive
Drives: 2012 Yaris SE
I have the Delrin sitting here just for that reason, but I'm uncertain if it will provide more gains over headaches in terms of bind. Perhaps something of a softer durometer to merely fill in the voids is the approach I may take.
NJ Drive is offline   Reply With Quote
Old 02-24-2013, 08:33 PM   #21
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
From what I've seen the suspension moves in a sideways arc so you'd need a ball and cup to accommodate the movement. Look at the mustang rear control arm bushings to understand what I mean. Going to a solid 1 piece would be a really bad idea.
Old 02-24-2013, 08:44 PM   #22
There is a TRD set:
48726-NP900 Rear suspension arm seat inner
48726-NP910 Rear suspension arm seat outer
Each side requires an inner and an outer. They are one of the standard upgrades for the Netz Cup Vitz race cars.
http://www.trdparts.jp/english/parts_bush-vitz90.html
Old 02-24-2013, 08:47 PM   #23
Actually a third part is needed: 48752-NP900 (one for each side {part 4 below}).
Old 02-24-2013, 08:51 PM   #24
racerb
There is a TRD set:
Attachment 49934
Attachment 49935
Those would probebly work best since in all likelyhood they are only about an 80 durometer bushing material. A urethane based mount would have enough give to not create so much bind. Or am I seeing them wrong and they are a delrin type material?
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-24-2013, 09:00 PM   #25
NJ Drive
Exactly my thoughts as well.
Old 02-24-2013, 09:02 PM   #26
NJ Drive
There is a TRD set:
Attachment 49934
Attachment 49935
You are my hero Scott. LOL, that's all I want. Now who can import these the fastest?
Actually a third part is needed: 48654-NP900 (one for each side {part 4 below}).
Looking over the part#s though, part #4 looks to be a front control arm bushing.
Old 02-24-2013, 09:03 PM   #27
Toyota lists them as "Resin", but I would suspect they are either Nylon or Delrin.
Old 02-24-2013, 09:11 PM   #28
Yarflana
Drives: 2008 Base Model
Perhaps I totally missed it, but what is the OP trying to correct, or improve? I completely saw the video and didn't notice any problem, but I am not well versed in suspension so I likely am missing the obvious to you track/racing guys.
Yarflana is offline   Reply With Quote
Old 02-24-2013, 09:40 PM   #29
NJ Drive
Just an FYI, JapanParts estimates $250 shipped to NJ for those white torsion beam bushings. Steep price to pay over an afternoon and some 3M window weld.
Old 02-24-2013, 11:48 PM   #30
xnamerxx
0-60 in slow
xnamerxx's Avatar
I was looking for lateral movement and found it.
So your asking why is that bad???
Well lateral movement is bad because you decrease the tractive capacity of the tires when there is deflection. What that means is during turn in when the rear suspension deflects the total amount of traction the tires can hold is reduced, when the suspension settles in mid turn you get more total traction, and then a decrease in traction during corner exit. So during transitional elements, think moose test or NATO test or Slalom, deflection in the rear suspension is really bad as it makes the rear want to walk away and makes the car unstable.
Old 02-25-2013, 12:06 AM   #31
Viperoni
Drives: 2005 Toyota Echo
Window welding the stock bushing would likely introduce bind... That JapanParts bushing is built such that it won't bind.
2006 Saturn Ion Redline
Old 02-25-2013, 12:20 AM   #32
xnamerxx
0-60 in slow
xnamerxx's Avatar
Here is a link to some real poly mix just as an FYI.
Poly Mix
Old 02-25-2013, 06:26 AM   #33
NJ Drive
I'm no stranger to Forsch casting urethane. Thank you though. Window weld isn't anywhere remotely close to even a 50A, as it has the consistency of silicone when it's hard. There'd be no risk of binding but in hindsight probably not worth the effort. Guess I just need to plunker down the dough for something TRD already engineered correctly.
Old 02-25-2013, 06:57 AM   #34
That's right - The correct part number for the rubber piece for the center of the resin pieces is: 48752-NP900 (Rear suspension support stopper)
Old 02-25-2013, 09:36 AM   #35
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
I installed the trd rear swaybar on my car on saturday and took it off on Sunday, made my car feel weird and didn't like the added oversteer made it feel sketchy on the freeway
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 02-25-2013, 10:12 AM   #36
NJ Drive
Scott, out of the parts listed, only the two white resin rings are applicable to the torsion beam bushing. 48752-NP900 pertains to a replacement bushing that resides on the shock shaft, just above the dust boot.
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
