Old 08-06-2013, 01:50 PM   #19
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Wow at least he offers good customer service ^^
Old 08-06-2013, 02:03 PM   #20
Jason@SportsCar
Originally Posted by 3cyltrbo View Post
-Tooter Manifold
-Corolla Throttle Body
-Coolant Bypass (Throttle Body)
-65 Deg Thermostat
-DC sports header
And the end result is that it feels like I've LOST 10-15hp ?????????????? (instead of having gained 10hp which is what I was expecting)
I was expecting to awaken a monster
I was expecting more noise
I was expecting some added power in the top end
Instead …………..
It feels like I'm driving around with AirConditioning on (I don't even have AC) with 3 passengers in the car (when in fact I've actually taken a bunch of weight OUT of the car)
I'm at a total loss.
If this is the way its gonna drive, I'll switch it all back to stock.
I would ditch that thermostat, that is way to cold, no reason at all for that on a street car - much less in the great white north. The ECU is probably dumping fuel in there in an effort to get the temp to what it thinks is normal, rich does not make power.
Old 08-06-2013, 03:06 PM   #21
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
Hey Will,
I have a 100% satisfaction guarantee. If you don't like the tooter, send it back to me and I'll refund your money, You'll only be out the return shipping cost. Then you can buy Garm's manifold if you think it will solve your problems.
Personally I think that something else is wrong, but that's not for me to figure out. So just send it back for an immediate full refund.
Greg
^^Awesome Customer Service!
But I wouldn't jump ship just yet, try some of the solutions offered. I'm no tuner but something is telling you that your not running optimal A/F ratio. Just swapping out the intake, I highly doubt, will solve your issues. I'd at least try the below solution:
Did you disconnect the battery after installing the throttle body to reset the fuel trims?
Did you per chance install each thing separately, where you could see the difference with each part?
If not, I would suggest reversing the process one by one, starting with reverting to the stock throttle body.
or
thats where your loss is from... go with the MI/GE one
LOL... you must be some expert to come to that conclusion... so quickly. Sponsored much?
JustDidIt is offline   Reply With Quote
Old 08-06-2013, 03:14 PM   #22
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I think that was meant playfully, not as a real suggestion. At least I meant it that way.
lol yeah I was merely jesting. I mean, yeah you'd get power haha, but I know most people don't want to dump 33% of the cost of the car into a supercharger.
Old 08-06-2013, 03:16 PM   #23
1.5
Form>Function
1.5's Avatar
LOL... you must be some expert to come to that conclusion... so quickly. Sponsored much?[/QUOTE]
nah just a huge supporter.
Old 08-06-2013, 03:43 PM   #24
^ He is not sponsored by us, if that was the implication.
Old 08-06-2013, 03:54 PM   #25
3cyltrbo
- Its never driven in the Winter
- Its only driven in summer (when our average temps are probably as high or higher (with humidex) than Sunny (dry) California and southern States.
- I've been keeping tabs on Intake Air Temp / Water Temp / Air-Fuel (among other things) and none of them have seemed wonky, but I'll go back and pay attention to the AF ratio while doing "pulls"
Will
3cyltrbo is offline   Reply With Quote
Old 08-06-2013, 04:17 PM   #26
47_MasoN_47
It gets 100+ with 60-80% humidity around here :P I sortof doubt it gets that hot up there.
I just use whatever thermostat came in the car and it works fine with boost and all the other junk I've got.
Old 08-06-2013, 04:19 PM   #27
3cyltrbo
Possible vacuum leak somewhere, maybe? Have you checked all the connections and listened for leaks?
You might try going back to a stock TB and see if that cleans it up at all. Our manifold accepts either throttle body, I'm not sure about the Tooter.
Remember, you've changed two or more things at once. It's best to change one thing at a time to see what the result is.
I have listened (my family calls me Miracle ears), and to the best of what I hear there weren't any leaks.
Of the areas where there could be a leak (below) they all seemed fine.
-Intake manifold to Head = check
-Throttle body to Intake manifold = check
-Intake piping = check
-Brake booster vacuum line = check (factory line)
-Evap system vacuum line = check (factory line)
-CrankCase vacuum line = check (exact specs as factory, only 1 inch longer)
-CrankCase fresh air line = check (breather)
-Exhaust Manifold to Head = Check
-Exhaust Manifold to downpipe = Check
-O2 sensor = check
I might start with just swapping back the OEM TB (Like many have suggested) and go from there................
Old 08-06-2013, 04:27 PM   #28
3cyltrbo
not to go too far off topic.............
Its funny that people think of Canada as the land of Igloos.
here in Ottawa (capital of all Igloos) its currently 78 F which is unusually cool for this time of year.
All through July we were mostly in the 90's, with many days in the 100+ range.
Admittedly our Winters are colder, but our summers are the 60deg F that people imagine they might be.
Old 08-06-2013, 06:36 PM   #29
Jason@SportsCar
You would be surprised at how a thermostat can put a car out of whack... This past weekend I helped my neighbor install a thermostat in his work van. It failed emissions, when he got the ECU scanned by a GM tech it was stuck in open loop mode, and would not get above 150f - which is about the temp of that unit you put it. In his case when he had the radiator replaced a few months back some knuckle head cut the core out of the thermostat (no idea why, could have been stuck), we put a new stock one in and now it passes smog.
I run a cooler unit, because we run a 30-40 min race and spin over 7000rpm, but I have complete control of my fuel via my AEM ecu.
On a road going car with a stock ECU you have done nothing but fatten up the mixture. No upside.
Old 08-06-2013, 07:43 PM   #30
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I do whatever satisfies the customer.
It's no problem for me to simply bead blast it again and sell it to someone else. I know that there's nothing wrong with the manifold because I've been running a tooter for over a year and 6,000 miles and it works great.
Jason mentioned the low temp thermostat, and I agree. I'd try removing that first because my guess is that it's screwing up the ECU which stays in "choke" rich mixture mode constantly waiting for the engine to warm up.
Old 08-06-2013, 10:26 PM   #31
Viperoni
Drives: 2005 Toyota Echo
Every few years or so, we get a day where we hit 120f with humidex, but that's rare.
Usually we'll get 5-10 days of 110f temps with humidex every summer.
3 weeks ago or so we had 5 days straight of 113f with humidity, it was nasty outside.
OP, as for the issue at hand, the main question is, when did the problem actually start happening? Or did you do all the mods at the same time?
2006 Saturn Ion Redline
Old 08-07-2013, 10:57 AM   #32
3cyltrbo
Its an easy enough swap (the thermostat) except for having to replace the leaked coolant - so I think I'll try swapping it back.
That and the TB swap are the easiest.
When I get some time this weekend I'll first try the TB and then the Thermostat.
Will
Old 08-07-2013, 11:15 AM   #33
3cyltrbo
3 weeks ago or so we had 5 days straight of 113f with humidity, it was nasty outside. ?
+1
I'm generally a pretty positive and optimistic dude when it comes to mods and the stuff that I read on the internets (YarisWorld etc..) (ie: "the web") so I honestly didn't expect any problem at all with any of the mods and hence I installed everything at once (header / Intake / TB / T stat / Silicone hoses etc...)
In actuality here were the problems I encountered:
-ARP exhaust manifold/head studs wouldn't install in the two outer locations (where the factory studs were (so right now for the DC Header I'm running the inner 3 head studs from ARP and the outer two head studs are factory)
-The Red Silicone rad hose from the head to the rad cap housing,..... doesn't fit the housing (its too big around) ( I notice in other peoples install pics they aren't running that hose and it makes sense why)
-The DC Sports header debacle with the O2 sensor bung being too close to one of the downpipe bolts
-The "Odyssey" battery (Sears Diehard Platinum) although a "standard" 35 size is actually marginally taller than the factory battery and therefore is a VERY tight squeeze for both the factory battery bracket and clearance to the Ultra Racing strut brace.
-I also had to fabricate my own Crankcase vacuum line because the Intake manifold side wouldn't fit the Tooter nipple(too small) (although the nipple for the EVAP vacuum and the Brake booster, both fit perfectly)
then of course I also forgot to re-connect the wiper motor so I had to tear the cowl off a second time to re-connect the plug.
Will
Old 08-07-2013, 11:25 AM   #34
Will
Based on Jason's expertise, I would do the thermostat first. As a quick and dirty test today, drive it and see if the green coolant light goes off. If it stays on and green, then you are in "cold start" mode. If it goes out, then the thermostat is likely not the issue.
Old 08-07-2013, 12:27 PM   #35
Why not?
Old 08-07-2013, 12:28 PM   #36
47_MasoN_47
That cold mode does a lot of weird things to the motor. I made a video a while back about how my boost behaves differently when the engine is cold.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
