Thread Tools | Display Modes |
#1 |
![]() ![]() Drives: 09 yaris hb Join Date: Jul 2010
I need to learn how to ask questions better haha :/ how are you finding the ride quality of the springs compared to standard? And especially after you've cut 1/4 from top and bottom? I'm looking at them on ebay and the only numbers on ebay page is Spring Rate Front/Back: 170 lbs / 200 lbs most other springs i've found have been front 5or6kg/mm and rear 3or4km/mm spring rate and I don't know how to compare those numbers |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
Why?
Why? The car's too low in stock form.
#3 | |
It's Quacktastic!
Drives: '07 Yaris Hatch Join Date: Aug 2010
These were some of the softest lowering springs I could find in my price range, and that's what I wanted, since the harder the spring you need the stiffer the shock you need to keep it under control. http://www.onlineconversion.com/foru...1110951659.htm You're kidding, right?? |
#4 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Here where I live we even call it "Innova fender gap." (Innova is an MPV/AUV)![]()
#5 |
Thanks D&D!! (Y)
Why?!?? haha |
#6 | |
#7 |
It's Quacktastic!
#8 |
![]() ![]() Drives: 2010 5spd sedan Join Date: Nov 2012
I think noobs should know to cover the sharp part of the fender with something to avoid slicing their hands open
#9 |
![]() Drives: 08 HB Join Date: Jan 2010
did you cut your bumpstops? ill post pics of mine here when i finish my install.
#10 |
na. i didn't see a reason to cut bump stops.
they are rather nice ride. went 2 weeks then got a whiteline sway bar definitely recommend a rear sway bar. |
| Tags |
| springs strut front m2 |
| Lowered Springs - Toe, camber, caster alignment (Which ones)? | Henry_mak16 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-22-2013 01:33 PM |
| my 2012 yaris lowered on trd springs | dailygrindin | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 05-04-2013 10:08 PM |
| Just got my Yaris YRX Lowered on King Springs! | theconspiracymarket | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-03-2010 11:26 PM |
| lowered it DF210 springs | mikenacarato | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 30 | 11-27-2008 10:22 PM |
| NEED A PLACE TO GO GET MY SPRINGS INSTALLED IN NORTH NEW JERSEY | smokinyaris | NY / NJ/ CT / PA | 23 | 06-26-2007 11:25 PM |
