Old 08-29-2014, 07:53 AM   #19
Maybe just an upgrade to a 1NZ manifold and throttle body might be all the upgrade you need. It would make sense that the 2NZ TB is smaller than the 1NZ.
Sent from my iPod Touch
Old 08-29-2014, 11:42 AM   #20
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's an excellent suggestion.
An issue would be converting from cable to drive by wire. If I had a cable, I'd stick with it. The throttle response is so much better than electronic controls.
Greg
Old 08-29-2014, 03:28 PM   #21
Greg
Why would he convert to drive by wire?
Old 08-29-2014, 11:02 PM   #22
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Sounds good, still trying to source a 1NZ intake manifold. How far off is a 2ZZ intake manifold in terms on bolting up to our NZ engines?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 08-30-2014, 12:45 AM   #23
tooter
play every day
tooter's Avatar
Actually he wouldn't if Toyota makes 4 bolt cable operated throttle bodies. I wasn't aware they did, but I could always be wrong.
Greg
Old 08-30-2014, 06:00 PM   #24
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The TB on my 1st gen Sienna was a 4-bolt cable style. I think I've seen some in the junkyard before. No idea if they're the same bolt pattern, and I'm sure they're HUGE compared to the one he already has.
Old 08-30-2014, 06:16 PM   #25
Greg
Re read the first post.
Old 08-30-2014, 07:05 PM   #26
CrankyOldMan
Crap. Now that we've completely derailed the thread, perhaps we can figure out if a 1NZ intake manifold would work?
Old 08-31-2014, 06:59 PM   #27
Ryze268
Ryze268's Avatar
I'm sure it will, I just need to find one first.
How far off are the inlet ports between an 2zz manifold & a NZ engine, Do you think an adapter would make sense?
Old 08-31-2014, 08:03 PM   #28
A 2ZZ manifold will not fit a 1NZ or 2NZ. It's ports for one are probably close to twice the size and is designed for an engine with an 8000+ RPM redline.
Old 08-31-2014, 09:04 PM   #29
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
1nz intake manifolds can be found easily. if anything ypu can find them all the time on facebook groups with folks from PTR on them.
Old 08-31-2014, 10:21 PM   #30
Ryze268
Ryze268's Avatar
Good thing I asked before I bought one.
Find me for cheap and I'll love you forever
Old 08-31-2014, 11:21 PM   #31
fnkngrv
fnkngrv's Avatar
What do you consider cheap? You do realize that you are saying this in a Yaris community so in my book cheap is very relative....seems like expensive here is cheap elsewhere
Old 08-31-2014, 11:33 PM   #32
Ryze268
Ryze268's Avatar
A new one is $100 on ebay so $50 for a used one seems reasonable
Old 09-03-2014, 12:45 AM   #33
fnkngrv
fnkngrv's Avatar
I can sell you my stock intake for 50 plus shipping. only thing is it wouldn't ship for a week due to business travel.
Old 09-03-2014, 09:07 AM   #34
Ryze268
Ryze268's Avatar
Just PM me when you get back
Old 10-29-2014, 09:27 AM   #35
Ryze268
Ryze268's Avatar
did you get this working?
I finally got around to doing the swap (3 bolt cable TB) yesterday, here is what I discovered;
The 1ZZ TB Requires longer bolts
A special 'gasket' had to be made
The Throttle Cable is it's stock position is too short
The car idles EXTREMELY high, minimum of 2000 RPM > http://youtu.be/XTNK8QxzM08
I'm still troubleshooting, hopefully I'll get it sorted out.
Old 10-29-2014, 11:33 AM   #36
You'll need to back the idle adjuster screw off a bit. It's set to idle a 1.8L.
wtb stock throttle body , cheap blacksandiegovitz Willing to Buy by private party 0 09-21-2012 10:32 PM
THROTTLE BODY SWAP NO CEL!!!! kou Performance Modifications 53 02-01-2011 04:01 PM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
