Old 06-26-2014, 07:29 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Throttle Body Swap Fail, help needed
Hey guys,
I have a 1300cc 2NZ-FE with a tiny 3 bolt throttle body. I recently attempted to upgrade it to a 51mm TB from a 1.8 7AFE corolla engine.
http://www.yarisworld.com/forums/showthread.php?t=51176
Unfortunately it didn't fit, the vacuum point didn't line up and the stock bolts are too short .
My next attempt to upgrade the throttle body relies on one you awesome fellas on the forums.
The stock US Yaris intake manifold uses 4 bolt throttle bodies, it should also mount directly to my engine.
I would like to know if anyone would be willing to sell me the stock intake manifold.
It would be greatly appreciated.
-Justin
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 06-26-2014, 09:44 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey Justin,
Sorry, man...
My CNC engineer had told me two months for a throttle body adaptor, but now he isn't available to do any of my tooter stuff. He's totally occupied working on really big projects now so I'm out of luck.
That's a better idea just to get a stock intake manifold. It would be way cheaper than an adaptor.
Greg
Old 06-26-2014, 10:40 PM   #3
Ryze268
Ryze268's Avatar
Its all good Greg, trial and error is key to moving forward.
The hardest part will be finding a used manifold, I haven't seen any on eBay.
Old 06-27-2014, 10:52 AM   #4
So as per your other thread, we said the 1ZZ throttle body works and you get one from a 7AFE
Um, why?
Old 06-27-2014, 11:22 AM   #5
? OP have a 2002, which have a cabled TB.
Old 06-27-2014, 12:53 PM   #6
I have a 2005, which also has a cable TB and so does the corolla before '03 with 1ZZ
Old 06-27-2014, 01:11 PM   #7
OH.. interesting, cuz i kept reading about 1zz DBW TB...
Old 06-27-2014, 01:12 PM   #8
Just like the 1NZ went from cable to wires, as so did the 1ZZ.
Old 06-27-2014, 06:55 PM   #9
mr_miles
Drives: 2013 Yaris
I might be able to get my hands on a stock intake manifold for you. I had an extra and a friend was going to use it on his XB, but he never did. I'll ask him if he still has it.
Old 06-27-2014, 07:05 PM   #10
Ryze268
Ryze268's Avatar
Um, why?
Also in that same thread, we discussed that my stock throttle body is 3 bolt while a 1zz throttle body is 4 bolt and wouldn't work. The 7AFE trottle body was the largest 3 bolt I could find.
Thanks much, I'd really appreciate it
Old 06-27-2014, 10:04 PM   #11
http://www.ebay.com/itm/351087676377
Sent from my iPod Touch
Old 06-28-2014, 10:38 AM   #12
Ryze268
Ryze268's Avatar
Sorry but that looks exactly like the one I have which didn't fit, I'll post some pictures when I get a chance
Old 06-28-2014, 12:01 PM   #13
http://www.clubxb.com/forums/showthread.php?t=28510
Old 06-29-2014, 04:42 PM   #14
Ryze268
Ryze268's Avatar
Thanks, it seems I have the 1zz throttle body after all but as suggested in that thread, I'll have to do some modding.
Thanks
Old 07-25-2014, 09:51 AM   #15
did you get this working?
Old 08-28-2014, 10:46 PM   #16
Ryze268
Ryze268's Avatar
Sadly I didn't, got some longer bolts, made the sandwich plate, installed everything and had a massive vacuum leak between the intake manifold and the tb.
I don't know but it seems the 2NZ-FE manifold is way smaller . I don't even think this mod makes sense on the stock manifold as the entry point on the manifold itself is about 35mm .
I'm going to try and source a 1NZ intake manifold or port out the stock one I have.
Trial and error is necessary, hopefully I'm helping someone who might attempt this as well
Old 08-29-2014, 01:30 AM   #17
tooter
play every day
tooter's Avatar
There are always challenges to adapting things to an unintended purpose. A 2NZ FE intake manifold is on ebay for $118. It includes free domestic shipping so that would offset some of the cost to ship where you are.
Greg
Old 08-29-2014, 06:24 AM   #18
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I reached a similar conclusion about the 1ZZ throttle body on the Blitz supercharger: the hole in the mounting face on the intake tube was the diameter of the stock TB, so I had to make a custom adapter that used the larger gasket, then connect the adapter with silicone couplers to a different version of the Blitz intake tube. Even if the original Blitz intake tube wouldn't have leaked, there would be very little HP gain because of the small tube inner diameter.
It took almost a year (on the calendar) to get all of the custom parts purchased and fabricated, and three separate tries to machine the adapter. I could repeat the process in about a week if I needed to, but the first attempt always takes me a long time. The next change will be to find and remove the new bottleneck, but that's probably going to require custom fabrication of cast or welded parts.
wtb stock throttle body , cheap blacksandiegovitz Willing to Buy by private party 0 09-21-2012 10:32 PM
THROTTLE BODY SWAP NO CEL!!!! kou Performance Modifications 53 02-01-2011 04:01 PM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
