#1 | |
![]() Drives: Vitz Join Date: Mar 2013
Mounts: The timing belt and rear mount are the same as for the 1kr engine( I had a 1kr not a 2nz). We had to attached a modified plate to the timing belt mount, since the bolts on the original mount did not align with those on the 2zz( as you can see in the picture. The original mount has a smaller aluminum plate which bolts onto the 1kr engine) ![]() The rear mount remained unmodified. But we had to make a custom bracket on the engine which would fit that mount perfectly. A new front mount had to be installed in the front, under the radiator. It was done by installing a reinforcement beam on the original beam and then welding the mount on top of it. This modification is totally bolt on( the whole reinforcement beam bolts on to the structure of the car, no damage done.) ![]() The transmisson mount fits in the same place as the 1kr but its an all together different mount with a custom made bracket which bolts on to the transmission. transmission. Im not sure which car that mount is from, probably an old corolla or a civic. Gear Linkage: The gear cables came with my 6speed transmission. We only had to install a manual shifter and connect the cable and after some adjustment it works very well. let me know if you need something more precise Wireharness: For the engine we used the original celica harness and for the cabine we used the original Vitz harness. Im not sure of whether the cabin harness had to be spliced or not ...sorry My vitz had an EPS and an electronic throttle. So we took the power steering pump off the 2zz and adjusted the fan belt accordingly. Im using the original EPS. For the throttle we had to make a hole for the throttle cable and fix a mechanical throttle. thats it. The AC still hasnt been fitted yet. So cant say anything. Ok for some reason the pictures did not attach. Kindly visit my photobucket to view the pictures, regarding mounts. Important things to notice have been highlighted. Hope all this helps
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
#3 |
What about on the pulley side. Did you have to mod the frame there?
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
Ok, question still stands.. which shift linkage did he use. Yaris or celica?
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#5 | |
ADMIN HELP!!!I'll make sure and let you know, But as far as I know we used the cable and shifter from a Corolla. |
#6 |
2zz Swap on Vitz/Yaris SCP90
Deleted my post. It's now irrelevant.
#7 |
![]() Drives: Yaris Sedan YRS Join Date: Mar 2013
Keep us updated on this one, thumbs up to you sir.
#8 |
Guys I need help with installing an OBD2 port. How do i install it to the new ECU? Anyone know how it is wired?
#9 |
Did you get your hands on the wiring diagrams for the car that you grabbed the ECM from?
#10 | |
There are numurous wiring diagrams available online, for the 2001 celica, but I cant understand the whole concept of how the ECM is wired to the OBD2 plug. Need help with that. |
#11 |
Updates:
Updates:
Got the cooling system sorted out. Initially there was no thermostat installed and the temperature sensor was not plugged to keep the fans running at all times. Now 82C thermostat has been installed and temperature sensor has been plugged back on. As a result the LIFT is working perfectly now AC condenser has also been installed. But having problem with the AC compressor. The 1KR compressor which was fitted on this 2zz has cracked . probably the reason being the smaller pulley size. And i cant install the original compressor because there is no room for a larger pulley. Someone advise?
#12 | |
Pin 16 is constant 12 V power Pin 4 and 5 are grounds Pin 7 is SIL, which is a direct connection to the ECM Pin 13 is TC, which is a direct connection to the ECM An OBDII reader communicates with the ECM via pin 7, which is the "K Line". For a standard OBD reader, just 4,5,7 and 16 are needed. Pin 13 is a toyota specific diagnostic wire.
#13 | |
Thanks for the response.but on the ECM end, where will all these wires be connected? or will only pin 7 be connected to one of the pins on the ECM? |
#14 |
![]() ![]() Drives: yaris Join Date: Sep 2011
wow..
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
