Old 03-24-2015, 07:40 PM   #19
Flammable
Flammable's Avatar
Drives: 2012 Yaris SE
Originally Posted by tmontague View Post
The 1NZ-FE does have noisy injectors, but if it increases in noise it could be your clearance. More than likely though I would check your front exhaust gasket, they tend to go every 120,000km or so and a leaking exhaust will cause a tick type noice during acceleration and a bit during idle. I just replaced mine on both my Echo and Yari and they are both much more quiet because of it.
In response to Bronsin's original post:
I checked my clearance at 125,000km on my Yaris, all were within range.
I am pullin the head off of my Echo next month to replace stem seals and clean out sludge. I will be checking the clearance before I pull it off and will replace the valve buckets if needed. The car has 347,000km on it so it will be interesting to see how the clearance is. It is only slightly louder than my Yaris other than the "new" water pump (replaced 1 year ago) that is now chirping on and off
Thanks for the info tmontague. My Yaris is a 2012 and only has 34,500 miles on her. I don't think the exhaust gasket is leaking but this is something I certainly will keep an eye on. When I get a chance I may post a vid of it running. :)
Flammable is offline   Reply With Quote
Old 03-25-2015, 10:29 AM   #20
I wouldn't bother checking clearances until the 180,000km range, based on the shape mine were in at 120,000km I won't be checking htem again for a while. My engine has stayed very clean under the valve cover so there is no reason for premature wear. My finacees Echo has some sludge (bought it used at 287,000km) so I'm not too sure what type of clearance I'll end up finding.
Old 03-25-2015, 10:03 PM   #21
Flammable
Flammable's Avatar
Sounds good and thanks again for the info.
Old 03-26-2015, 06:10 AM   #22
bronsin
bronsin's Avatar
I'd be suprised if the clearance is out of spec high and expect it will be slightly out of spec low. But it might be OK. Many must be.
Old 03-26-2015, 07:20 PM   #23
Flammable
Flammable's Avatar
It's funny there used to be a recommended mileage interval to check valve clearance and then Toyota did away with that recommendation all together. I have heard of people putting a ton of miles on their Yarises and never checking the valve clearances one time. I imagine there is the occational engine that will have valve issues but it appears that is rare with these motors.
Old 03-26-2015, 07:25 PM   #24
After dismantling the head I'm working on, I was surprised that the valve had no visible makes from their seats. It's like they were all new still. I think the head oly had about 60k KM though so relatively low milage but still, I thought I'd see something. I think they have a coating of some kind on them.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
Oil Pan Drain Valve guy2can DIY / Maintenance / Service 16 01-06-2018 05:06 PM
PCV valve check ; Can it be done this Hershey DIY / Maintenance / Service 7 03-31-2014 09:33 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
