Old 01-03-2016, 10:11 PM   #19
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yeah, the engineering world is surprisingly cutthroat when it comes to knockoffs.
I spent a bit more time today going over the wire harness. Took off all the A/T stuff that isn't needed, made a few pin swaps to get some M/T wiring in the right spot, and started cleaning up my wiring schematic. Looks like the harness I bought is missing the TPS--bastards just chopped it right off instead of removing it. There are still about 10 wires on the E4 connector, since I don't know for sure what signals the ECU requires to operate. I'm going to put together a spreadsheet with the pinouts of each ECU connector to help with collaboration.
I also scored a '14 Yaris A/T ECU and engine wire harness today as well, with the intention of making a piggyback wire harness adapter from it.
Old 01-03-2016, 10:21 PM   #20
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Same pinout as our current gen TPS?
Also what are you going to do about the throttle body and IM?
Sent from m-o-b-i-l-e
Old 01-04-2016, 06:43 AM   #21
CrankyOldMan
No, it's the previous gen with separate TPS and IAC valve.
I'm not 100% sure what the plan is for IM. Somewhere between all OEM bits, a 1ZZ (cable) TB, and the Blitz S/C. I had also debated using the Yaris manifold and adapting a universal TB, but that means no IAC--which may be a pain in the ass.
Old 01-04-2016, 09:11 AM   #22
fnkngrv
fnkngrv's Avatar
Ah ok. That is a bummer.
Old 01-04-2016, 09:59 AM   #23
'02 Corolla Used a cable throttle if your looking for a bolt on upgrade.
Old 01-04-2016, 06:42 PM   #24
CrankyOldMan
I looked at that on some Scion forums. Needs a block off plate for the difference in IAC channel locations, but seems to be a decent option.
Old 01-04-2016, 09:21 PM   #25
CrankyOldMan
I added a link to a spreadsheet in the original post with the ECU pinout and wire colors. If you would like to add to it, PM me the info, or I can add you as an editor.
Old 06-08-2016, 03:51 AM   #26
madgarage
Drives: red
Where have you found the exact pinout for the ECU?
Im looking for 3 days now and i can't find it.
I have swaped the engine and the wiring loom.
my first ECU was a Bosch 0 261 208 036 89661-0D210
and the second is a fujitsu 89661-52065
And even if have changed the whole engine harness there is one connector which is different, it was connected from ecu to the blue plug, but in the new ecu the blue plug is missing
madgarage is offline   Reply With Quote
Old 06-08-2016, 07:08 AM   #27
CrankyOldMan
I purchase a subscription to techinfo.toyota.com. Looks like you're in the UK? You should probably use https://www.toyota-tech.eu/ to make sure you get the right manuals.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Does anyone know what wire harness is in the 09? Yarrris-Wench In Car Entertainment + Electronics (audio / video / alarm) 2 05-27-2010 07:44 PM
