Old 05-11-2016, 06:52 PM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
This exact setup? On a 5dr with 205/50/r15 on 15x5.5" rims?
Nope, but played around with front strut bars. No bueno. Actually took my front sway bar off completely at one point to help with some front tire contact in the slaloms. Just wasn't flowing for me and my driving style.
Again, to each their own. My setup has got me to a 1st place National Tour twice, but then again, my driving style is a bit different. I don't even left foot brake.
higher octane do make a difference...after i upgraded to E85 with larger injectors and ecu, i gained good 10whp+
My point was that people who drive a yaris with no mods feel that the car is faster if they use 91 octane over 87... Also, that feeling that your car is faster after you fill it up.. SMH
-Derrick-
Old 05-11-2016, 08:43 PM   #20
Jason@SportsCar
Originally Posted by CoryM View Post
Yeah, it always comes down to keeping the driver happy. You're right, mid corner shows a hint of understeer, but immediately transitions into rear rotation so I am OK with it. It's very brief, to the point you don't have time to correct it before it sorts out. As far as camber, I was after more contact patch on the inside tire, which the front bar gains and more neg camber reduces.
I can't see it being in my head. After 4.5 years of racing the car, put the F bar on and after 3 events to get used to it and tune pressures: I'm certain on this car at these autoX events it is faster. I realized last night I'll just run my wet tires for the winter series and hope for enough wet days to compete. You've run this setup? This exact setup? On a 5dr with 205/50/r15 on 15x5.5" rims? .... why?
As far as the front bar goes I want to be clear: I did not install the front bar to control balance. When chassis tuning, I always try to maximize grip first, then adjust until balance is right. This is the same as tire pressure tuning; maximize grip with temp probe or chalk, then adjust pressures to reduce grip where needed for balance. The sway bar does the same, except I am using it to help compensate for the high CG. I wanted more grip from my inside front tire, and the front swaybar accomplished this. I was able to reduce neg camber up front to -2.5° (which I forgot to include in my first post), this not only improves the inside tire contact patch further, it also makes a large difference to the braking grip(VS -2.8° which was my previous). After adjusting the balance with rear tire pressures, I am comfortable that it is well set-up, and the co-drivers (once they get used to timing the soft springs) agree so far. I also have pictures to show I have much more contact patch than before.
Who knows, maybe I'm crazy but I've always figured the whole point of suspension was to keep as much rubber in contact with the road as often as possible (or at least when it's required). The front bar seems to accomplish this without causing too many compromises so I am happy.
All that being said, the Yaris is now getting totally forgotten about while I sort out the E-mod car for it's first season.
Cheers.
Swaybars build grip on the opposite end of the car they are attached to. They do this by providing a lifting force to the inside tire - as the outside tire compresses the swaybar transfers the load and pushes the connected tire in the same direction. You are in fact reducing grip on the axle the bar is attached to.
Swaybars in general are a crutch for a poorly tuned suspension. That said, you are limited in HS with the mods you can do, and one of them wont be fixing the lack of spring rate, so you do what you can. In a fwd car the last thing I want to do is remove front grip, and that is what a bigger front bar is doing.
I would go the other way and find a way to transfer as much grip from the rear of the car to the front. Go with a bigger rear bar, or get a set of proper rear shocks that will help suck up that back tire quicker, forcing grip to the front.
In our car we dont even run a rear bar, just droop limiters in the rear shocks that pick the back tire up almost instantly.
Old 05-11-2016, 08:46 PM   #21
Jason@SportsCar
Originally Posted by rabbito View Post
sway bar do make difference, so does front tower strut...higher octane do make a difference...after i upgraded to E85 with larger injectors and ecu, i gained good 10whp+
Sent from my ASUS_Z00AD using Tapatalk
A front strut tower brace will offer no improvement on a Yaris if you are still using the stock upper strut mounts. You have a strut that is mounted in an inch thick rubber doughnut, that is not even positively affixed to chassis, the damn thing just floats in there.
Replace the top mount with a proper bearing plate first, otherwise you are just burning money.
Old 05-12-2016, 04:26 AM   #22
ilikerice
ilikerice's Avatar
^^^This^^^
What I was trying to say, but much better worded and technical.
-Derrick-
Old 05-12-2016, 05:43 PM   #23
CoryM
Drives: 2009 5-door, 5-speed
That way of thinking is definitely the right path for the vast majority of FWD cars. This is why I waited so long to try a front bar on my car. Where the traditional way of thinking goes wrong is Stock class when the CG is high and/or springs are too soft. High body roll, high neg camber and struts cause the inside front tire to lose a large amount of contact patch. In my car I was losing ~1/2 of my inside F tire contact patch. That's a lot of rubber, and it shows everytime I try to accell out of an element.
Yes the F bar loses grip by transferring weight to the rear, but it also gains grip by almost doubling the contact patch of the inside F tire (and gains a little outside F contact patch due to reduced pressures). Is this enough to net more F grip over all? No idea, but it sure feels like it. If I had the tire-curve, I could do a bunch of measurements and math to figure out which gains more grip (on paper). In practice, it would take a serious test and tune session to confirm one way or the other.
Again, this pretty much only applies to HS cars and maybe only over-tired HS cars. It's possible it needs R-comps to see gains, and maybe this winter running my street/wet tires will show the front bar to be detrimental.
Old 05-12-2016, 05:58 PM   #24
Jason@SportsCar
Not sure who sold you on that, but if you like it go with it.
Old 05-12-2016, 07:06 PM   #25
CoryM
I was sold by seeing the car on course from outside, photographs, experienced co-drivers' opinions (after they have driven the car), my understanding of suspension design, and that the car feels faster through many sections on course. More rubber with less dynamic load, or less rubber with more dynamic load: Unless someone does a test and tune (or some serious engineering) of both setups there is no way to confirm which nets more grip, in more situations, on this setup.
Old 05-12-2016, 07:59 PM   #26
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Hmmm...your OP states that you have Tokico blues installed? I've heard they are a pretty stiff shock. Why not try some softer shocks with the front bar? That way, maybe you can load and unload your tires at a faster rate and be able to further increase your tire contact with the road.
Just another idea, but like you stated above. No way to really find out without some serious tests, and proper math.
Old 05-14-2016, 01:50 PM   #27
CoryM
I could definitely do better in the shock department. I'm not sure what the blues are intended for, but stock springs is not it. I only got them because I needed something to replace a damaged OE strut. The Yaris only gets new parts when it *needs* them. The whole point of me driving the economical car is to spend less on it so I can spend more on faster cars . This is also why I've stayed in HS as it reduces the temptation to buy stuff for the little car.
Cheers.
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
