#19 | |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Yariseggvvti started a thread that got derailed into peoples' personal mileage with rear brake shoes, no results. Brushforhire started a thread that included lots of good technical details and pictures of donor candidates but he crashed his car and the thread kind of died. |
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
Cause I have a JDM rear beam axle. And a 08 yaris.. 😂 But you can piece together a setup with usdm toyota parts from other cars.
"It hurts more when its wet" |
#21 |
feed my pet
I did enquire with a mechanic regarding rear disc conversion and he briefed me with 2 options.
First option was to swap the entire rear axle complete with disc. Costs with labor would set me back $425. ![]() Second option requires minor modification to my rear axle. He mentioned that there was no mounting holes for the rear calipers. This is where drum/disc axle differs. He needs to mount a fabricated metal plate/bracket for the calipers. He also needs to cut off the back part in order to install this plate/bracket. Photo 28-07-2018, 03 14 15.jpg the metal plates/brackets beside calipers Also he mentioned that the hand brake cable for disc/drum are different so you need to swap that too. |
#22 | |
this. thank you. i've been saying that for years. btw can i get that bracket? lol. |
#23 |
feed my pet
#24 | |
XD |
#25 |
feed my pet
Enviri, I believe the above photo is the JDM conversion kit bracket so the fabricated metal bracket might look a little different. That place is out of the way from any place I would visit but I'll try to go by and take a photo of the bracket and ask the price. You gotta be patient thou.
#26 |
I have the Runstop rear disc conversion. As SOON as I have a chance I will have the brackets sent out. Just don't have cash and the conversion is still on the car.
#27 |
#28 |
dinky huh. you do know that the rears are larger in diameter than non rs brakes, with no ventilation lol.
#29 |
Dink in comparison to a normal sized cars rotors, and yes the disc rears would be bigger than a non rs brake rotor.... if I were running that. I'm running Matrix front brakes right now per the swap guide. the rears are still dinky
#30 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
suggestion because people have told me in the past, better pads. when those shit the bin, better calipers and brakes. |
#31 |
feed my pet
I did swap my front discs & calipers to the JDM G grade/package. They are slightly bigger and the swap was quite straight forward.
#32 |
![]() Drives: 2012 Sedan Join Date: Nov 2018
I'm considering getting a used SE hatchback axle for my sedan. where can i check the specs to verify fitment? they should be the same right?
#33 |
The BodyArchitect
Drives: Yaris Sedan 2015 Turbo AT Join Date: Dec 2015
Could you please tell me the measurements of the disc.
| Tags |
| disc, disc conversion, drum |
| Possible DIY rear disc conversion | brushforhire | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 25 | 01-22-2024 03:36 PM |
| Yaris Rear Driving Lights Problem | ap222 | DIY / Maintenance / Service | 3 | 05-31-2013 05:49 PM |
| drum brake conversion to disc brake | bogartvitz | Performance Modifications | 8 | 04-15-2013 10:21 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
