Old 05-24-2007, 12:55 AM   #19
hans_fh
Thanks Blacksan! I would let you know if I go to East Coast:)
hans_fh is offline   Reply With Quote
Old 05-24-2007, 02:31 AM   #20
Pavel Olavich
Drives: 2007 Yaris LB
I generally fill up the crank case just before the oils starts to run out the the valve cover....one can never have too much oil in their motor...why stop at 4 quarts? Just fill her up and rest assured your engine is well protected...I think the last time I changed the oil it took 9 or 10 quarts...
Pavel Olavich is offline   Reply With Quote
Old 05-24-2007, 08:53 AM   #21
nsmitchell
nsmitchell's Avatar
Here is what I do and it works quite well.
Buy 4 quarts of oil.
Pour in 3.5 quarts. I use 1 of the first 3 bottles to measure out a half a quart, and keep the other half.
Drive it. Let it sit on a level surface and check it again. My oil level is always perfect to the top of the dipstick fill line. If it needs any more, add it in small increments.
Works perfectly every time.
Get YarAss in gear!
RIP - Casey Tatum
Old 05-24-2007, 10:31 AM   #22
Astroman
Modded Moderator
Astroman's Avatar
You better be joking
Old 05-26-2007, 08:43 AM   #23
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
None!
Old 05-27-2007, 08:59 PM   #24
foober
Drives: two yaris liftbacks
My first oil change I did myself I put in 3.7 quarts of 0-30 amsoil. And it registered over the top bar on the fill bar on the oil stick. So I emptied some. I now just put in 3.5 quarts and it winds up being just about right with the fill bar on the oil stick. Thats with changing the oil filter as well.
foober is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
