Old 10-29-2010, 11:18 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I brought the car to my tuner that specifically recommends Haltech ecus. He worked about 2 days trying to start but the engine persist to misfire and cannot remain idle at all. We checked the triggerring signal and it seems to be inconsistent everytime we try to start the engine. He also tried to vary filtering levels but invain.
My tuner is about sure that the problem might be coming from an issue specifically related to the 36-2 + 3 Sequence Toyota use.
Garm, did you had any issues with your AEM ecu regarding triggering?
Old 10-29-2010, 12:45 PM   #2
^ no problems at all, sorry!
Old 10-30-2010, 02:39 AM   #3
Parmas
Parmas's Avatar
The problem is about sure that is a software issue but we need Haltech support to solve it before we continue.... sooo the car goes back again into my fu..ing garage.
If haltech will not solve it within the next month I have no choice but to make custom triggering wheels for the crank and the cam using Haltech Hall Effect sensors.
I hope this would be the last issue as I am really pissed of about this engine and it is making me sick.
Old 12-12-2010, 08:26 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
they (haltec), may have told u this already, the crank trigger settings are the same as the scion tc (they flew to our shop to create basemap on our dyno). are you using the sport 1000 or sprint 500? if you ever run into the issue of accelerating hard thru the gears and then the car hits a "cut", pm me and ill tell u the fix, has to do with the crank trigger voltage and filter settings.
cool build!
Ptuning.com
Old 12-13-2010, 08:19 AM   #5
Parmas
Parmas's Avatar
cool build!
Hi man, the issue wasn't the triggering but the ignition modules. Haltech replaced them with built in ignitor coils and worked like a charm.
Now I am tuning the engine myself and till now I done mapping of the engine with 9psi boost and 5000rpm [with AFR LOW 14 / HI 10.5 (boost) ]. This week I am preparing the car for the final tune which is the 2ZZ intake. If all goes fine, I have to retune the engine for the larger o/d of the 2ZZ intake Throttle Body (70mm) and runners
Old 12-13-2010, 07:15 PM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
sweet, love that haltec software i bet. It is really nice. That 70mm throttle body should open up a lot of power.
Ptuning.com
Old 12-15-2010, 04:15 AM   #7
Parmas
Parmas's Avatar
After my experience with this unit, I can say it is worth the money and since now I seen no issues with it. Solid rock ecu, full of description on all option tabs ( a must for beginners ) and reliable performance. Also to consider that it is good for almost any engine and features latest cam control technology + stock sensor compatability.
I am no expert on tuning, and with this unit I was capable to tune a reliable 9psi boost till 5000rpm (at least for now :) )
I am hoping better response with this intake. Let's be straight, If any would tell you what do you prefer between a custom intake or a Toyota proven one, I vote for Toyota and here it is!
I hope it will be ready for a christmas present to my self
Old 10-30-2010, 02:07 PM   #8
oh man that is tough -- so sorry you've gone through so much to get this far, but it's SO close now!
Old 11-20-2010, 12:43 PM   #9
Parmas
Parmas's Avatar
ITS ALIVE IT'S ALIVE
A fu*king ignition module was the reason. Thanks to haltech support I was able to solve the problem after they got me replaced with new coils instead. Now it idles like a sweet girl smiles at you and rev up like never before and this only with a map sent from haltech!!
Now I need to install the last few bits:
- NST 3x pulley kit
- Nitto torque damper
- Celica 2ZZ-GE intake manifold + 2ZZ-GE 72mm throttle Body
Also I noticed that from the output hole of the turbo (that goes into the intercooler piping) it leaks some oil from it. It happens when revving much the engine. Could be the seals of the turbo that need replacement or should I leave it?
What I need to do? Is it expensive to repair it? What are the items needed?
Old 11-20-2010, 12:52 PM   #10
congrats that is awesome
Old 11-20-2010, 01:51 PM   #11
Parmas
Parmas's Avatar
What do you suggest about the turbo oil leak problem garm?
Old 11-20-2010, 03:43 PM   #12
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
What's your oil pressure like when u rev it?
Old 11-27-2010, 03:26 AM   #13
Parmas
Parmas's Avatar
And look what arrived yesterday!
A 2ZZ intake with a 70mm throttle body! Tried fitting on spare engine and there are only minor issues to solve :
- To mate the 1NZ intake flange with the 2ZZ intake
- Some clearing issues on the front ( It could be that the intake hit radiator piping)
- Right Mounting holes
- Increase length of right intercooler pipe due to throttle body at an angle
If this works I cannot say what are the gains but at least I can show that it can be done!
Old 12-07-2010, 02:13 PM   #14
Parmas
Parmas's Avatar
Please check this thread.... http://www.yarisworld.com/forums/sho...932#post539932
Old 12-13-2010, 07:45 PM   #15
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
the human head weighs 8 pounds
Old 12-15-2010, 06:57 PM   #16
Do you have any pictures of the progress on the manifold? Is he just custom fabricating the upper portion of the manifold so it fits the 1NZ head and the lower part of the 2ZZ manifold?
Old 12-15-2010, 08:27 PM   #17
cdydjded
Drives: Yaris LB Turbo
I dont & will never claim to be an expert, but thx for the compliment ; )
I can tell you that long manifold runners are not made for boost, short runners are. So a manifold with shorter runners would improve airflow on boosted application. But there are many factors that need to be taken in cosideration such as:
Turbo size
Boost level
Cylinder head flow
Intended use (street or strip)
Im going to read over all of Parmas posts to give you my thoughts on the matter....
cdydjded is offline   Reply With Quote
Old 12-15-2010, 08:59 PM   #18
cdydjded
After reading 21 pages of post all I can see is an engine that makes 250hp & that Parmas cant stop adding parts to his car. He need to stop making adding thinga & tune & dyno the car as it is. Thats my 2 cents...
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
