Old 07-22-2009, 09:44 PM   #397
Originally Posted by Vince87 View Post
I've already tried that.... And the on/off switch I'm speaking is the one before the resistors and were the pin40 and ground wires are attached...
I had missed this above:
"I did check the extra switch with the meter before doing the swap and they were ok (0 resistance when unpressed, high value (1) when pressed)... "
This indicates that the switches are the wrong type. They are normally closed, rather than normally open switches. Unpressed should be high resistance and pressed 0 resistance.
Old 07-22-2009, 09:56 PM   #398
Vince87
Drives: 2007 2DR Yaris
Wow ! I thought that normally open switches were "normally" allowing current to flow but it seems to be the opposite... sorry for that I should have checked by myself before... Thanks a lot !!!
Vince87 is offline   Reply With Quote
Old 07-22-2009, 11:06 PM   #399
texkid
The one with cheese on it
Drives: '10 Corolla S
I am not sure if I found the right one on eBay??
This is what I am going by in my search for the switch......from the first page.
This is the closest thing I can find.....and here is the LINK to the eBay listing
So did I find the right one?
Or can someone please send me towards the right direction, perhaps?
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-23-2009, 07:02 AM   #400
That will work.
That listing doesn't have a part number listed, but the correct part number is: 84632-34011
On the Camrys the same stalk as the Yaris one was used from 04 to 09.
In the picture on that listing the wire that goes from the switch to the connector on the spiral cable is missing. Part number for the wire is 84633-42030 and it goes for about $30 from the dealer.
Old 07-23-2009, 11:34 AM   #401
texkid
That will work.
Thank you very much. I just made an offer to the seller. In the meantime I will keep on looking around to see what else i can find.
Added Note:I was just on TRDSparks.com, their website is stating that part number 84633-42030 is being replaced with part number 84633-02020. I am not sure if that is correct so I thought I give ya'll a heads up.
DIY: A/C Insulation
Old 07-23-2009, 12:06 PM   #402
84633-02020 is shown in the EPC as being for the 08-09 Corolla and Matrix, but perhaps it is the same, so they are merging the two part numbers.
By the way, in looking for stalks, ones from the following vehicles are all the same:
Camry 04-09
ES300 04-09
Scion TC 04-09
Sequoia 04-09
4Runner 04-09
Corolla 08-09
ES350 06-09
FJ 06, 08
GS450H 06-09
GX470 04-09
Highlander 04-09
IS F 07-09
IS250 05-09
Land Cruiser 04-09
LX470 04-09
LX570 07-09
Prius 04-09
RAV4 04-09
RX330 04-09
RX400H 05-09
Scion xB 07-09
Scion xD 07-09
Tundra 04-09
The 84633-42030 wire is supposedly only used on the following vehicles:
Corolla 08-09
RAV4 05-08
Yaris 06-09
Old 07-23-2009, 02:20 PM   #403
texkid
That list will be very helpful whenever someone is looking for the stalk on ebay. There are SO MANY pre-1996 stalks on eBay. So one really has to sift through the listings to find the right stalk. Of course, if you have the money and time, one could always just go to the dealership or TRDSparks and just order the right part. I ordered the Cruise Control Clutch Switch from Sparks and I might end up ordering the wiring from them as well.
BTW, just so ya'll know. My local dealership was charging $40 for one wiperblade assembly. I called TRDSparks and ordered the driver and passenger wiper blades plus the clutch switch all for just under $50 including shipping! Freaking awesome!
DIY: A/C Insulation
Old 07-23-2009, 02:35 PM   #404
toddo
toddo's Avatar
Drives: 2009 LB
Just finished this mod on my '09 LB 5-speed. Works great! Big thanks to everyone that provided part numbers and ebay links.
toddo is offline   Reply With Quote
Old 07-24-2009, 08:21 AM   #405
Vince87
Just drove to work with my newly working cruise control, this is amazing ! thanks a hundred times CTScott ! So it's now confirmed that the mod works on the Canadian model of the yaris (mine is a 07 MT liftback)... Next step is to install the Clutch Switch and the On/Off LED !
Old 07-24-2009, 03:49 PM   #406
ehud42
Drives: 2009 Yaris Sedan 5spd
D'Oh! Why didn't I find this thread 3 weeks earlier.... Just got back from a 2 week, 5,000km road trip in my 2009 Yaris sedan (5 speed) - without cruise... Loved the car, but my back and legs were soar from the hours of driving.
On a plus side, my mileage was low 6's / 100km and even a couple of 5's in the mountains (less then 90kph). I think in mpg (imperial/cdn gallon) that works out to 45-47 with one of my fill ups tipping past 55mpg!
I am very tempted. I have not read any comments regarding warranty. I suspect that any damage caused by installing or using these methods would not be covered, but would the warranty be voided if a mechanic saw this?
If I do the mod, I'll probably put the switches in the holes cut out for seat warmers - down by the gear shifter / hand-brake.
$10 for the bits, plus a clutch switch and my '09 is good to go, eh?
I am so tempted....
ehud42 is offline   Reply With Quote
Old 07-24-2009, 03:54 PM   #407
PatrickJohnson
Drives: 2008 Yaris LB
at least in the U.S...
WARRANTY CLAIMS CANNOT BE DENIED UNLESS THE DEALER CAN PROVE WITH CERTAINTY THAT THE MOD DIRECTLY CAUSED WHATEVER FAILURE IS BEING PRESENTED FOR WARRANTY REPAIR....
The burden of proof for denial of warranty claims is on the dealer in U.S., can't imagine Canada being much different.
PatrickJohnson is offline   Reply With Quote
Old 07-27-2009, 09:36 PM   #408
texkid
I found this DIY post on ToyotaNation. Granted, it was done in 2006 and it was a Tacoma. But after viewing the pictures, they OEM stalk install looks a lot like ours, plus he skims over the Clutch Switch install. And I mean "skim". Like two pictures and thats it. I need something better than that.
Here is the LINK to that thread.
I just received my stalk from eBay and the wire should be here by the end of the week. I promise guys, if I can get this done, I'll post a DIY for our Yarii with clearer pictures. Y'all know how OCD-ish I am about DIY pictures.
DIY: A/C Insulation
Old 07-28-2009, 01:06 AM   #409
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I'm looking forward to that, I won't attempt it on mine until I see a DIY for a 2008, since it's not pre-wired for cruise, and I really want to use a stalk, not a homemade button setup...
Old 07-28-2009, 11:03 AM   #410
I finally found the info on the correct terminal with the waterproof sleeve for the ECM connection. It is the female terminal with the waterproof sleeve and 500mm of wire attached. It is intended to be a repair item for a damaged terminal, where the tech just has to splice the wire, rather than having to deal with attaching the wire properly to the terminal.
The part number is: 82998-24250
Old 07-28-2009, 12:14 PM   #411
texkid
I am going by what CTScott said in the conversation below...If what you're saying is true, then I am going to need a little more time to figure it out.
Originally Posted by Henry G. View Post
Just to confirm after reading 24 pages.....this will work on an '08 MT but you need the stalk, the clutch switch and need to do some wiring to the fuse box, correct?
Correct. We really need to do a DIY for 07-08's...
DIY: A/C Insulation
Old 07-28-2009, 12:57 PM   #412
We need to DIY, so that all of the info is concisely packaged.
Doing an 07-08 is really not difficult, and quite a few have already done it.
I would just like to get the soup to nuts of it nicely documented, so that everyone's questions are pre-answered. I have been meaning to write one up myself from the pictures that nickhjort sent me when he did his, but I haven't had a chance.
Old 07-28-2009, 01:02 PM   #413
texkid
No problem. I just need the wire assembly from TRD Sparks. If I do get it by Friday or Saturday, I will be doing it right then and there.
DIY: A/C Insulation
Old 07-30-2009, 12:00 AM   #414
texkid
Okay...I am at a lost.
I received the wire from TRDSparks. I installed the cruise control switch and the clutch switch. Nothing is turning on or engaging. I then jumped the wires in the fuse box to bypass the clutch switch...still nothing. I then took off the airbag again and double-checked the wires, everything is locked in.....still nothing. I even connected the white wire to the purple wire and found out that it starts the car!! I am not getting any "Check Engine" or "Airbag" lights in the cluster, so that's a plus I guess.
Could I possibly just have a bad cruise control switch or am I missing something?
If y'all have any ideas, I am all ears.
ADDED CORRECTION: Umm....I think I just screwed up....I have the '08 LB, so I had to connect a blue wire from the ECM to the connection behind the steering wheel, right?
DIY: A/C Insulation
Last edited by texkid; 07-30-2009 at 12:31 AM. Reason: A light bulb just went on over my head...
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
